Noise with Amsoil Filter
Old Feb 2, 2004 | 02:44 AM
Mossback74's Avatar
This became apparent after I did the Deckplate and put in the Amsoil filter.
It’s an "intake whistle" that happens when the engine is under load at 2-3k RPM.
With the deckplate in place it is less noticeable but still present.
With the deckplate off and paper filter its almost totally gone.
I knew there would be more intake noise after the deckplate but it seems like it’s the filter that makes the most difference.
My Runner has almost 115k so I'm thinking it may be a clogged Cat.
Any others have this noise? Or is it normal?
Old Feb 2, 2004 | 04:40 AM
MTL_4runner's Avatar
I don't have any noise from mine.
Old Feb 2, 2004 | 04:45 AM
Spectre's Avatar
I have no noise with mine either..are you sure that it is seated right?
Old Feb 2, 2004 | 04:56 AM
Mossback74's Avatar
That was one of the first things I checked after making sure no vacuum lines got disconnected. The edges were pretty oiley and kept slipping out of the corners on the first install. I wiped them down and they stayed. Also I stuck my hand through the deckplate (airbox off) and felt around to make sure it was making a seal.
Old Feb 2, 2004 | 05:45 AM
rimpainter.com's Avatar
My rig makes that same whistle. It's a the turbo - didnt you know?
I wouldn't worry about it. Mine has done that for the past 10K miles (deckplate mod installed).
Old Feb 2, 2004 | 06:09 AM
Mossback74's Avatar
I guess that will be my excuse.
The pseudo turbo 4runner
Old Feb 2, 2004 | 10:53 AM
Tacoma Dude's Avatar
Mine has also been doing that for the last 6 months or so.
At first I thought it was radio static and kept reaching for my radio that was turned off
crammit442
7
Nov 29, 2017 12:30 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Iceman4193
Aug 28, 2015 08:43 PM
norcal98
Aug 10, 2015 06:20 AM
calderp
Jul 27, 2015 09:58 AM
