new u joints and im still vibrating in the rear end!
Old Jun 23, 2010 | 06:55 AM
kennyb3030's Avatar
hey guys, noticed a vibration at speeds of 60-70 mph about a week ago, so i toss it around with a few friends of mine and they seem to think its u joints. so i take it to the dealer and they check it out and say the u joint in the rear is bad and i should replace both the front and rear u joints and i say ok, picked the 4r up this morn and it did ride alot better with the new u joints but at 60-70 mph i start to feel vibration in the rear end. i feel no vibration in the steering wheel or the front end, just the rear. and it also makes a nobby tire sound in the rear sometime to, where should i go from here to solve this problem?
Old Jun 23, 2010 | 07:52 AM
snobdds's Avatar
If your having the death wobble at only a specific speed, then it is tire related. If you have a constant death wobble at all speeds and you can feel it in the steering wheel then it is driveline related. Have you rotated and rebalanced your tires lately?
Old Jun 23, 2010 | 08:01 AM
kennyb3030's Avatar
had the tires rotated and balanced about 15k ago, so im due for a tire rotation, probably do that in the morn and go from there
Old Jun 23, 2010 | 10:51 AM
gdutch's Avatar
Check out the information here about tire balancing:
http://www.4runners.org/writeups/haweka/index.html
Old Jun 25, 2010 | 09:14 AM
kennyb3030's Avatar
mechanic looked at the rear end yesterday and it looked fine, so i had him rotate the tires, and sure enough, the vibration moved to the front, having the tires balanced monday morning on the road force balancing machine at the dealer, hopefully this fixes my vibration problem..
Old Jun 25, 2010 | 09:25 AM
waskillywabbit's Avatar
Typically check tire balance first, then other stuff if you got vibrations. It is the most common and easiest to fix or rule out.
Old Jun 25, 2010 | 10:22 AM
toyomoto's Avatar
Originally Posted by Gnarly4X
Getting a "road forced" tire balance won't do squat.
all that does is counterbalance the heaviest part of the tire to the heaviest part of the rim making it as centrifugally balanced as possible. you still got to balance the pair afterwards.
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
Daneums
Aug 20, 2015 05:36 AM
hangtown88toy
Jul 10, 2015 02:33 PM
akaphilly
Jul 9, 2015 02:18 PM
