New sparkplugs/air filter = bad mileage
Old Jan 18, 2007 | 08:50 AM
gpcollen1's Avatar
There has been some discussion on the necessity of gapping dual electrode plugs. I installed some new plugs and the factory gap was in the .03_ range. I decided to leave the gap as set by the factory. My gas mileage has not been what it should so I just recently regapped to .04ish - more akin to the .044 spec. The jusry is still out on my gas mileage right now.
There is no good reason not to gap the plugs close to spec.
Old Jan 18, 2007 | 09:04 AM
Tanto's Avatar
The factory plugs come out of the box at .034 and the factory specs recommend .043 or .044
I'm thinking that the sparkplugs for the 3.4L are used in different engines so that's why they manufacture the plugs with a .034 gap. Can anybody confirm this?
Old Jan 18, 2007 | 11:11 AM
GOH10 Runner's Avatar
this is going to sound really stupid but which batt cable should i pull in order to reset the ECU?
Old Jan 18, 2007 | 11:14 AM
Elton's Avatar
the negative one..... on a side not when i replaced my plugs in my truck for factory denso's i didint gap them and it runs like a champ and gets atleast 21mpg
Old Jan 18, 2007 | 12:10 PM
  #25
gpcollen1's Avatar
Do you remember what the gap was from the box?
Old Jan 18, 2007 | 12:13 PM
  #26
MTL_4runner's Avatar
I have always installed them straight out of the box and never had any issues. Also keep in mind the gap grows as the plugs wear so being a little on the small side isn't bad either.
Old Jan 18, 2007 | 12:55 PM
  #27
91TPU's Avatar
upon installation of mine i check the gaps, made sure they were good, some were off by a bit some by a decent margin, gapped em, and put em in, its really not that hard to gap em, takes 5 minutes max for all six
Old Jan 18, 2007 | 01:59 PM
  #28
sharrack's Avatar
My recent plug electrodes were football shaped when I removed them.
Whew! Should have done it sooner..K.S>
Old Jan 18, 2007 | 03:39 PM
  #29
BruceTS's Avatar
Originally Posted by MTL_4runner
Well, obviously there may be an anomaly here and there (pehaps in manufacturing supply, perhaps they had been changed at the dealer prior to delivery, etc). I would still maintain that if you have Densos on one bank and NGKs on the other, you're probably dealing with the original plugs on the vehicle.
Originally Posted by nick-m
Well, I wouldn't go as far as saying that isn't true; I had the same exact thing and I've heard of others having a 50/50 of Denso/NGK plugs from the factory...for instance, my '96 had Denso plugs on one side and NGK on the other. They were original...pretty much everything was original, actually, when I bought it....10 years after it was made
I'm not disagreeing with the Denso/NGK combination from the factory, all I'm saying is not all 4Runners had it.
Old Jan 18, 2007 | 03:52 PM
  #30
gpcollen1's Avatar
ALso remember that with the dual electrode, the plugs should wear half as fast as single, as there is only one spark per firing. It takes a bit of time to wear them down when the engine is running right.
Old Jan 18, 2007 | 04:14 PM
  #31
Yep, exactly!
.....not as good as iridiums, but light years better than a standard single electrode plug.
Eggslinger
Jun 8, 2019 03:32 PM
montanatruck
Feb 26, 2017 07:07 AM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
anniesball
Jul 30, 2015 12:14 PM
calderp
Jul 27, 2015 09:58 AM
