New here, have a clutch disc question
Old Apr 4, 2004 | 12:26 PM
cverner's Avatar
Hi everyone. I recently picked up a 94 4x4 22re w 130Kmiles. I am in the middle of a clutch job and have come to a delema.
The asco clutch disc that I bought has rubber chunks in it instead of the spring type that I am removing.
So I did a couple searches and see more 2 or more people have said the rubber type discs do not last like the spring type.
Is this true? I can't imagine how this effects wear, but is there any reason I should not put the rubber type in? Comments?
Old Apr 4, 2004 | 01:42 PM
TechWrench's Avatar
The rubber 'chunks" you refer to are installed as a type of shock absorber.
They are supposed to do the same thing as the springs, cushion some of the force generated, when the clutch is engaged, between the friction plates and the center hub. I can only speculate at to why the manufacturer went to the rubber bushings instead of springs, (cost)? But it would seem to me that the rubber bushings would be more likely to fail sooner that the spring, IMHO. I would guess that is what the other people meant, not that the friction plates failed but the bushings.
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
1996Taco
Jul 20, 2015 12:02 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
