NEED U-bolt bottom plate 85 solid axle!!!!!
Old Mar 15, 2005 | 09:10 PM
Yoda's Avatar
Just installed new lift kit. Looks good, but doing the next day check, my son found the U-bolt plate on the drivers side is cracked (This is the front axle....The correct plate is flat to match the reinforced axle) I had another plate, but it is for a round axle
ANYONE HAVE ONE OF THESE!! Close to the Seattle area would be great too.
Old Mar 15, 2005 | 09:32 PM
DudeBud's Avatar
i might be able to help you. you need the drivers side right?
Old Mar 16, 2005 | 04:29 AM
Yoda's Avatar
Yeah, its the drivers side. I'll try to post pics of where the crack is (Edge of steel plate to the U-bolt hole). We have 2 drivers side plates, both from 85's, but they are different. Maybe production date thing.
The one we need has a flat reccess in the plate (there the OEM reinforcement of the axle is) and all the edges are rolled up. If you find the one you have, can you post a pic?
I have a landcruiser axle to deliver to a guy in Monroe, so I could do double duty.
Old Mar 16, 2005 | 05:16 PM
DudeBud's Avatar
if you could post a pic of the one you need that will help kinda sounds like this truck has an older front end in it
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
gieselman
Oct 12, 2015 01:34 PM
Scotto6591
Sep 1, 2015 03:24 PM
scottyg486
Jul 19, 2015 05:34 PM
