need help
Originally Posted by 86_4runner
hi
is it possible to use a 22r engine from a 84 pickup in a 89 pickup that is a 22re?
well I did a little research and i found that you can swap the two motors. I talked to someone who done it on there 4runner.
other than that, go for it.
I don't Know if you are carb. or injected, but also keep in mind if you are injected and the other motor is carb. there may not be a provison for a knock sensor. That is what I'am talking about just the little stuff that would drive a man to drink lots of beer.Good luck!!!!!!!!
