need help!
Old Mar 9, 2007 | 07:12 AM
mauibuilt's Avatar
Arrow need help!
hi everyone.
i been told that if i put 15x12 rims on my tacoma 2002 they will rub?
i have a 2002 tacoma 4x4 TRD 3 inch lift i want to put 31x10.5 on 15x12 MT is it going to rub. the rim has a bs 4" it will fit over the calipers.can someone who knows first hand tell meif it will rub and on what .right on!
Old Mar 9, 2007 | 08:21 AM
breknraj's Avatar
So, if I'm reading this right, you want to mount a 10.5 inch wide tire on a 12 inch wide rim?!?!?
I put my old '90 alloys and 31"s on the 3.4 donor Taco (just so I can still roll it around), with a 4" lift, and they look like roller skate wheels. I would think that you would want bigger tires, in both dimensions, for the rims you seem to be talking about.
Old Mar 9, 2007 | 08:27 AM
mauibuilt's Avatar
you still didnt answer my question! whatz up!
Old Mar 10, 2007 | 10:19 AM
breknraj's Avatar
I didn't answer because I have no idea about rubbing issues with that wide a rim, although I would suspect that you would have some. Mostly, I'm trying to understand the reasons for such an odd combination of rims and tires.
Old Mar 10, 2007 | 10:56 AM
Elton's Avatar
lol good luck getting a 10.5 tire on a 12'' rim and more than likely there going to rub
Old Mar 10, 2007 | 12:54 PM
etan's Avatar
hows it braddah?!?!?! haha. there is chance you'll rub but then again with a lift and the tires stretched i guess you wouldn't rub. if anything you'll need less backspacing or a extended studs and wheel spacers.
I know for most of you this combination doesn't make sense. but it's possible, i've seen many stretched tires over rims. its a style back in the islands. not to say that i would do it, but its a possibility.
