need FSM for 98 tacoma
I have looked through the posts about the Factory Service Manuals. I'm trying to find the FSM for 98 tacoma 3RZ, but the closest I see is a link for the 1996 manual. Will this one cover my truck also? I know those years are similar but just want to be sure. Thanks again for your help.
I think the only significant change between 96 and 98 is the ignition. 96 has a distributor, 98 does not. There are likely numerous small changes in the wiring harness.
96-98 there were lots of significant changes. Interior, exterior, wiring, ignition, etc etc etc.
It all depends what you need the book for. If you are trying to do an engine swap into an earlier vehicle (2nd gen 4Runner or truck) you need the correct year book. Wire colors are different, etc etc.
At this point its only for mechanical upkeep and repairs. I have downloaded the 96 FSM. If I needed to buy one, where is a could source, either for a hardcopy or for a digital version?
Go here. pay 15 bucks. Download all you want for 3 days..
The guys that have done 3.4 swap use this.
https://techinfo.toyota.com/techInfo....toyota.com%2F
Longbed 90
03-11-2019 12:38 PM
FS[FourCorners]: First Gen Tacoma/4Runner Manual Hub Spindles
G-off
12-29-2015 12:44 PM
accuracy
09-20-2015 07:44 PM
Boomer8404
09-20-2015 06:15 PM
