my sunroof is stuck
Old Mar 20, 2009 | 06:18 PM
Ladythump's Avatar
my sunroof is stuck
99 4Runner Limited
My sunroof will neither slide back or tilt up. I push the button and I hear the motor but the roof seems to be stuck. Is there a way to push it open or should I just have the dealer look at it??? I'd rather see if there is something I can try myself first.
The temps have been in the high 30's lately so I don't think it's frozen with rain/snow but it might be.
Old Mar 20, 2009 | 06:21 PM
97ltd4x4's Avatar
Possible cable problems...big$$$...1K+ if its the cables
Is your moonroof is closed(flush with roof)?
If so,you might just want to unplug motor and go without using the moonroof?
Old Mar 20, 2009 | 06:23 PM
Ladythump's Avatar
yea it's closed flush with the roof.
How would I know if it was the cables?
Old Mar 21, 2009 | 06:05 AM
97ltd4x4's Avatar
If its the cables,generally one side will try and move out of sink with the other side and jam-up..The teeth on the lagging side has a bad tooth/teeth,so the motor cannot move it....You can inspect them w/o removing moonroof assembly.. but its a tedious process....remove motor,remove glass,look up where the motor gear meets the moonroof assembly with a really strong flashlight and slowly move the cables one side at a time looking for a damaged tooth/teeth......generally if the motor moves at all the problem will be with the cable(s)...
Oh,and I believe the cables will run $200-250,but its like 8 hours of labor(headliner removal,moonroof assembly removal,disassembly of moonroof tracks),so yea,unless you can do it yourself still gonna cost some big$$
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
Redeth005
Jun 28, 2018 08:16 PM
CPD4runner
9
Nov 5, 2017 06:01 AM
ToyotaMD
Sep 7, 2015 04:44 AM
