My ECU took a crap...
Old Oct 1, 2003 | 10:17 AM
Angry My ECU took a crap...
That's what the repair shop said anyways. Not a fuel problem like I originally suspected. Going to cost $695 to get a junkyard ECU put in. Pretty gay, but whatever. I'm selling the damn 4Runner as soon as I get it back. I can't afford to keep running this damn thing.
Old Oct 1, 2003 | 10:53 AM
mtnfreak's Avatar
$700 is pretty steep. Bet you can find an ECU for a lot cheaper and install it yourself. 3 or 4 wire plugs and 2 bolts - takes longer to get the kick panel off than to replace the computer.
Old Oct 1, 2003 | 10:55 AM
RTdawgs's Avatar
get a 2nd opinion on the ECU.
check www.car-part.com for part(s) you need.
Old Oct 1, 2003 | 10:57 AM
flecker's Avatar
From: White Mountains, Arizona (Yes it does snow in AZ)
I agree, always get a second Opinion. Like Mtnfreak said, it's real basic to "do it yourself".
Old Oct 1, 2003 | 10:58 AM
hillbilly's Avatar
Maybe TOR can get you a better $$$???
Old Oct 1, 2003 | 12:31 PM
Memphis4X4's Avatar
Re: My ECU took a crap...
Originally posted by J Rock
[B]That's what the repair shop said anyways. Not a fuel problem like I originally suspected. Going to cost $695 to get a junkyard ECU put in.....[B]
What were the symptoms of your problem? I ask because my shop told me that my ECU was going bad (they gave me a line about the diodes in the ECU were starting to fail......yeah right). I was having injector issues, where there was power to the injectors but the ECU was not completing the circuit to allow the injectors to inject fuel at start up. The shop swapped ECU's and the problem still occurred. They then threw up their hands and gave me my truck back unfixed. I found the problem.....it was an engine ground that had worked itself loose. It was the ground on the back of the passenger side of the motor. I put the bolt back in and tightened it......fuel, injector, and starting problems are fixed.
If you are having similar problems....check that ground.
David
Old Oct 1, 2003 | 12:35 PM
rimpainter.com's Avatar
Sounds like a load of crap to me. I agree with the other guys, second opinion all the way.
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
bradahman
Oct 1, 2015 09:24 AM
Boomer8404
Sep 24, 2015 01:12 PM
Dobich
Sep 14, 2015 11:15 PM
zz_denis
Sep 6, 2015 03:43 PM
