Old Mar 30, 2016, 09:38 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma 4WD - Four Wheel Drive Guides
Print Wikipost
My drive shaft went bye bye, how much will this cost me?
Old Jan 18, 2009 | 11:06 AM
irunner's Avatar
Have been having vibration problems for a while now, bought new tires, still no luck, yesterday the vibration got much worse, now it shakes when i take hit the gas around 20 miles per hour. I looked under my car today to see this
1997 4runner, SR5,2wd. no lift, 265/75/16 on back and 265/75/16 on front
UPDATE! Went to Autozone and bought some Duralast u-joints then took them to a Driveshaft shop, they replaced both front yokes and replaced the u-joints all for a whopping $68! Truck runs like new, no more vibration or noises.
Attached Thumbnails My drive shaft went bye bye, how much will this cost me?-photo.jpg
Old Jan 18, 2009 | 11:10 AM
DeathCougar's Avatar
More info?
Old Jan 18, 2009 | 11:16 AM
irunner's Avatar
It's a 1997 4runner, SR5, 2wd.
Old Jan 18, 2009 | 11:17 AM
toyNG's Avatar
x2 more info. What are you driving? Any lift? etc...
It'd be a good idea to keep pertinent information about your rig in your signature line.
Old Jan 18, 2009 | 11:18 AM
irunner's Avatar
My bad. No lift, 265/75/16 on the back and 265/70/16, everything else is stock.
Old Jan 18, 2009 | 11:19 AM
v6? 4cyl? auto? manual?
Old Jan 18, 2009 | 11:38 AM
904_runner's Avatar
A u-joint is like what $20?
I can't tell if it did damage to the actual driveshaft or not.
Old Jan 18, 2009 | 11:39 AM
mt_goat's Avatar
Looks like someone was too stingy with the grease.
Old Jan 18, 2009 | 11:41 AM
irunner's Avatar
V6, auto
Old Jan 18, 2009 | 11:42 AM
irunner's Avatar
That's the only part that is messed up, Can i just replace that part alone?
904_runner's Avatar
My mom's 1999 v6 2wd automatic 4runner, didn't have zerk fittings for the u-joints. So there wasn't an option to grease them
Old Jan 18, 2009 | 11:43 AM
904_runner's Avatar
Yes you can just replace the ujoints. Your going to have to remove the whole driveshaft and pound the rest of that one out and replace it. If you have the extra cash you might think about doing the other one too. When you get new u-joints make sure they are greaseable.
Edit: I was just looking at the photo again and it looks as if it may have messed up the driveshaft a little.
Old Jan 18, 2009 | 11:44 AM
irunner's Avatar
Originally Posted by Buhundred
Did it come with 265/70/r16 tires from the factory?
I bought it used and it came with 265/75/16, not sure what it came with stock from the factory.
Old Jan 18, 2009 | 11:47 AM
scuba's Avatar
To save youself alot of trouble, Take the drive shaft off and take it to a Driveline shop to have them replace the u joints and balance it...hell you might make away with a new paint job on the beast. PS. Your drivers side door jamb sticker will say what size tires came from the factory.
Old Jan 18, 2009 | 11:52 AM
irunner's Avatar
Thanks guys, i'm going to go take more photos, should be about 10 minutes.
Old Jan 18, 2009 | 12:03 PM
DailyDrive's Avatar
I see absolutely no grease. It should have slinged over the adjacent surfaces and stayed there. Doesn't look like it's been ever greased?
Old Jan 18, 2009 | 12:14 PM
irunner's Avatar
Here's another pic from a better view, it took a little chunk of the driveshaft, i'm going to order two u-joints and replace them both at he same time, and grease them properly, any tips on installing u-joints?
Attached Thumbnails My drive shaft went bye bye, how much will this cost me?-photo-1.jpg
Old Jan 18, 2009 | 12:21 PM
Meterpig's Avatar
That was unfortunate. In that case, you can drill, tap and insert a zerk. I might have been cheaper than dealing with this problem.
I am religious about greasing the zerks underneath my 99 4runner.
By the way, a driveline shop is the way to go. No guessing, muss or fuss.
Old Jan 18, 2009 | 12:50 PM
irunner's Avatar
What's a reasonable price on replacing two u-joints and balancing?
Old Jan 18, 2009 | 01:34 PM
scuba's Avatar
I payed 117 when I took mine to a shop during number 2 cause I fubared the yoke. So 135 max..
