Mud Tire on pavement type sound?? Tried but can't stop it!?
Old Apr 24, 2010 | 08:19 AM
ohio4runner4x4's Avatar
Question Mud Tire on pavement type sound?? Tried but can't stop it!?
On my 2000 4R I have a sound that is almost the exact same kind of sound that you would get from mud tires on pavement. The tires on it were Toyo A/T's and they were 5 years old and cupped so I figured that was it.
So here's what I have done to try to stop the sound:
1. Bought new tires...Yokohama Geolander HTS which are just about street tires and that didn't make any difference.
2. Changed the front & rear differentials + transfer case oil and replaced with Amsoil Severe Gear 75w90 - no difference
3. Greased all u-joints - no difference
So now I am out of ideas and the sound has not gone away or even slightly got quieter.....and I can't pinpoint where its coming from either...just underneath.
Please help with any $.02 or ideas......cuz it's drivin' me crazy!
Thx
Old Apr 24, 2010 | 09:05 AM
Mud Mut's Avatar
It could possibly be your wheel bearings. Did you check those?
Old Apr 24, 2010 | 09:06 AM
Elton's Avatar
really man black font just dont work
Old Apr 24, 2010 | 09:07 AM
Mud Mut's Avatar
I know I didnt notice it at first lol
Old Apr 24, 2010 | 10:24 AM
Question
Ok...more info: jacked up the back end and ran it. The sound is definately coming from the rear end. Wheel Bearings or Pinion....how do I tell?
Old Apr 24, 2010 | 10:55 AM
yotaman85's Avatar
unbolt your drive shaft from the pinion and check for excessive play.
Old Apr 24, 2010 | 01:41 PM
Gerdo's Avatar
Pull the rear third, have the gears inspected and re-install on an ARB locker using all new bearings.
Put it back in and see if the noise is still there. If so then it's the wheel bearings.
OR while the axles are out to pull the 3rd just replace the wheel bearings also.
It could be a U joint in the rear driveshaft. Pull the driveshaft and drive it in 4wd. If its gone then it's in the driveshaft.
Old Apr 24, 2010 | 04:30 PM
Ironmike4x4's Avatar
Best way is to get a mechanics stethescope from an autoparts store. Have someone to put the vehicle in drive and you get under it with the scope. Go from the rear diff to the outside of the axle tubes to find where it gets louder. If it's at the end of the tube then most likely it's the bearings, if it's louder at the diff then it's something internal. However, if it IS the diff then I'd just go ahead and replace the bearings and seals at the end anyways just for future security. "Do the job once, not twice"
Old Apr 25, 2010 | 07:58 AM
groober's Avatar
I'll assume you've checked to see if the axle seals perished. 3rds, I've read, are notorious. I had to have my rear carrier overhauled. Pinion bearing was the culprit. Very labor intensive. I had the work completed at a local shop. $900. Good as new now.
Old Apr 25, 2010 | 08:04 AM
B4Runner's Avatar
Or, just put the truck in neutral and get a good grip on the drive line to check for the play.
Old Apr 25, 2010 | 09:39 AM
RubyRhod's Avatar
^^ what he said.
Old Apr 25, 2010 | 11:18 AM
Birdbrain's Avatar
Why did nobody list the best fix for this kind of stuff?
Turn your music up.
Old Apr 25, 2010 | 11:38 AM
B4Runner's Avatar
OP, when my pinion bearings where going out, they sounded more like a big rig's exhaust when it's downshifting. Maybe you can relate the two since they are semi-similar.
What I did to replace it was just replace my whole 3rd member. $900 to replace the bearings or $100-150 to just pick up a good 3rd. I chose the $100-150 option.
Old Apr 29, 2010 | 04:46 PM
Smile
It's the pinion bearings.......found a 3rd member for $250 from these guys!
http://www.yodajims.com/
Old Apr 30, 2010 | 05:46 PM
LINY4Runner's Avatar
great people over there! got my TJM from them, very nice and very helpful! definitely recommended!
djpg2000
Nov 11, 2020 04:56 AM
Eggslinger
Jun 8, 2019 03:32 PM
Yota.Jay
Oct 24, 2015 08:41 AM
Sep 4, 2015 09:27 AM
PlayAwhile
Jul 20, 2015 11:36 AM
