More Alternator Help
Old Oct 13, 2003 | 12:29 PM
fourunnabilly's Avatar
Guest
Question More Alternator Help
Hey guys-
First off, I have to give you all a big thank you for the continued help. The problem is almost solved. I have a question about the alternator. I know the 3 wires that plug into it are the IG, S, and L...correct me if I am wrong. Regardless, I am positive that when the key is in the start position, but the vehicle is not running, the IG wire should ready about 12V, which it does. When I turn the key I get a click, click, click. So the main quesiton is: What purpose does the large black 4 gauge wire running from the alternator do? Is it a ground or a power source. Also, if you think I should check any fuses, let me know. I did blow the IG1 under the daxh and replaced that one. I'll take anything you guys can give me. Thanks again. I'll get some pics up soon, as I am sure you all want to see a 4th gen that is making some headway.
Billy
Old Oct 13, 2003 | 01:42 PM
bomberyota's Avatar
Read the post about the starter contacts you can buy them from Roger Brown this should solve your problem this clicking thing is common with toyotas
shooter86314
Jan 7, 2016 07:05 AM
Chicken12
Oct 14, 2015 03:54 PM
fountain
Sep 28, 2015 03:04 AM
SCZIG
Sep 20, 2015 09:00 AM
scheuvront1993
Sep 17, 2015 06:17 PM
