Misfire - ECU Bad?
Old May 12, 2025 | 09:54 AM
Yodahelp's Avatar
Misfire - ECU Bad?
Hello all. New member here and new to the Toyota world. I need some input. Sorry for the long post but I want to give you detailed background.
New to me 2001 Tacoma 2.7l 4x4 auto trans, 206,000 miles, started missing. All plugs are good and confirmed spark through the plugs. All coils good. Compression is good with 180+ on all cylinders. Pulled all injectors and bench tested. All work as they should when activated with a 9 volt battery and all spray the same pattern. Injectors are good.
Injector no. 3 is not clicking (determined by a listening device) with engine running. Confirmed 12v to one side of the injector. Noid light gets no reaction when plugged into no. 3 wiring harness with engine running. Signal wire from no. 3 injector connector to the ECU is good. Continuity test confirms.
The question: Could the problem be anything other than the ECU? Parts house code reader tells me what I already know - misfire on #3, replace injectors. I don't know how the computer knows when to send the signal to the injector, but could a damaged or very dirty reluctor wheel create such a problem? I have no reason to believe it is damaged - just trying to troubleshoot.
I appreciate any insight and assistance.
Old May 13, 2025 | 06:15 AM
Jomoka's Avatar
Sure, that's one of a dozen or more things that could cause a misfire.
Old Dec 26, 2025 | 01:52 AM
75w90mantraN's Avatar
Reluctor wheel? Dont think injectors involve those. Usually solenoids.
Its possible to have continuity but still poor or high resistance. Ohms check both the injector and the wiring between that and the ecu. And verify reliable ground.
Did you have batt voltage to the injector when ignition on engine off or running?
Sandsailor1
Sep 25, 2024 05:19 AM
Rustycan
Jan 22, 2017 05:58 PM
Pete1122
Jun 4, 2015 04:41 PM
dgraham
Jun 12, 2012 08:25 PM
leeeeeroy
Feb 5, 2010 05:04 AM
