Midnight Brainstorming about ADD 4WD What do you think?
Old Jun 10, 2004 | 08:23 PM
corvettelvr73's Avatar
OK let me be the first to say it that I am cheap however when something needs to be done right to avoid failure in the future Ill do it right. If the cover that locks the front cv axle to the hub (cant remember the name of it) that is held on by screws was removed would this reduce drag and kinda be like a manual hub with a little more work needing to be done to go into 4wd?
Old Jun 11, 2004 | 06:41 AM
keisur's Avatar
no. you'd end up with an open hole in the ADD actuator and stuff would get in there. the way to do it would be to install manual hubs and permanently lock the ADD system.
http://www.4x4wire.com/toyota/tech/add/
Old Jun 12, 2004 | 03:56 AM
HondaTec521's Avatar
How would you engauge 4 wheel drive ? Reinstall the covers ? what about dirt getting into the bearing/hub area ?
Old Jun 12, 2004 | 06:17 AM
keisur's Avatar
The ADD cover he is talking about is located on the side of the diff so the hubs abd bearings wouldn't be exposed. the dirt would get into the ADD Actuator. see the site I posted for pics of the ADD.
Old Jun 12, 2004 | 06:55 AM
Robinhood150's Avatar
No, I think he's talking about the ADD flange...AKA, the part that is replaced when manual hubs are swapped in.
Old Jun 12, 2004 | 02:39 PM
keisur's Avatar
Ahh, I just reread it. I get it now. haha, might as well just pull the diff then because you wouldn't need it.
Daenerysdad
Oct 1, 2015 07:33 PM
icentropy
Sep 10, 2015 05:03 AM
Tcsdef
Sep 7, 2015 11:17 PM
May-39
Sep 6, 2015 01:05 PM
BigMike
Marlin Crawler
Sep 3, 2015 07:49 PM
