Messy steering
Old Nov 28, 2003 | 07:21 PM
Yoter's Avatar
Guest
Question Messy steering
Ok I was up on a trail run and got into indestructable mode. I decided while dropping down an incline I would explore a side trail. I dropped over into the side trail and there was a deep hole. I just dropped like a rock into it. My steering wheel whipped out of my hands and cranked hard left. I had to maneuver out backwards to get out. Upon hitting the pavement when back down at the base my steering wheel was off and the truck wandered while driving down the road. I fixed my broken idler arm that was clicking when steering but my steering wheel is still off and the truck still wanders. Whats up wit dat? Blue
Old Nov 28, 2003 | 07:38 PM
ByThaBay's Avatar
probably need an alignment. i have a 2wd and my steering wheel was out of alignment and vehicle kept dragging to the right, so i had my alignment done and everything is perfect. just make sure you take it to a very reputable shop 'cuz a lot of places will do very poor alignment jobs.
Old Nov 28, 2003 | 07:42 PM
nightsurfride's Avatar
Sounds to me like you either bent one or both of your tie rods ( depending on what vehicle we are talking about) or your toe is out enough to not only put your steering wheel off but cause a directional pull. Tipically toe needs to be out quite a bit in order to cause the vehicle to pull. Otherwise I would check for bent or damaged front end suspension parts and visit a compitant and trusted alignment shop.
Old Nov 29, 2003 | 09:42 AM
Mad Chemist's Avatar
Hey Blue,
I'd guess bent tie rods too. BTW- we've got 4ROC stickers now if you're still interested...
Old Nov 29, 2003 | 10:18 AM
Yoter's Avatar
Guest
Originally posted by Mad Chemist
Hey Blue,
Oh wow yes definently, who do I send money to and how much?
Old Nov 29, 2003 | 10:54 AM
Cebby's Avatar
Probably an alignment. The tierods aren't as weak as the H2's
Old Nov 29, 2003 | 02:23 PM
KevyWevy's Avatar
hey blue, why aren't you on wa.4roc.org yet?
Old Nov 29, 2003 | 03:01 PM
Yoter's Avatar
Guest
I am! I resigned up as Central Wa Offroader. Ive been hiding out not playing on YT or 4ROC for the past month or so. BUT Im backkkkkkkkkkkk!
ladybugRC
458
Aug 21, 2020 10:41 AM
live4soccer7
May 11, 2016 06:52 PM
scott90
Oct 4, 2015 09:21 AM
ktm192k
Oct 1, 2015 08:47 AM
gentry
Sep 28, 2015 06:16 AM
