Looky what I got today!!!
Old Oct 10, 2003 | 08:37 AM
rimpainter.com's Avatar
Hey Rob-
Let me know what everything costs you, install...everything. I am liking that set-up more and more.
Old Oct 10, 2003 | 08:43 AM
AznSky's Avatar
well total for parts and shipping was 658.74
Which includes:
4 OME Shocks
4 OME Coils
Diff Drop Kit
Front Trim Packers
Shipping was 50 bucks. So for you it might be cheaper, cuz these got shipped out of Colorado as Mike doesn't carry any OME parts.
I don't plan on paying anybody for install, maybe spending some on tools and renting a spring compressor, but that money is returnable.
Old Oct 10, 2003 | 09:10 AM
shazaam's Avatar
hopefully this will work a lot better then taking off those running boards, huh?
Old Oct 10, 2003 | 09:21 AM
turboale's Avatar
The hardest thing about the install is mounting the spring on the shock. I couldn't find a spring compressor that would work so I gave up as I was already at school and didn't have all of my dad's tools with me. A wall mount takes about 10-15min to put them both on, so i'm sure if you have a buddy with a shop or something they would do it cheap or free. Then the install is simple as pie. Good luck!
Old Oct 10, 2003 | 02:16 PM
  #25
INsr5runner's Avatar
Originally posted by PoBoy
Wahoo, way to not jump on the SAWs bandwagon!
Thats what I said, even bought the axle...but then I sold it :cry:
BOOO shoulda sold it to me!
Old Oct 10, 2003 | 02:18 PM
  #26
Rob lets try for the 25th weekend. if you want those "other" guys to help you, then FINE. JERK:pig: J/k
I will ask for the 25th weekend off. Even thought that is the IOWA game (LAST BIG home game of the season)
Old Oct 10, 2003 | 02:21 PM
  #27
TDiddy's Avatar
Prediction:
Iowa 38, Purdue 10
Old Oct 10, 2003 | 02:23 PM
  #28
RTdawgs's Avatar
Originally posted by Gadget
Where are the front shocks???
Those ARE the front shocks.
Brain fart? (ahhhh, much better)
Old Oct 10, 2003 | 02:32 PM
  #29
Originally posted by mertztr
Prediction:
Iowa 38, Purdue 10
Prediction Ditka 390, mini-bears 10
BOOO MERTZTR! IOWA WILL BOW DOWN TO STEW. Nikko gets better and better too!
Old Oct 10, 2003 | 02:33 PM
  #30
AznSky's Avatar
Ok sounds good Mike. I should get an answer from these guys this upcoming week. If not, I'll just use their tools.
Yay I got my rear shocks in today!! I guess the stuff I got yesterday was sent by High Country out in Colorado, and the rears were sent by ARB out in WA today. So that was the mix up, and the diff drop kit should be on its way now.
btw is there such a thing as using TOO much PB Blaster? Cuz I soaked my bolts today and plan on soaking them until I get them off , for some reason I don't know how to get to the top of the rear shock. Any ideas?
Old Oct 10, 2003 | 03:21 PM
  #31
Mad Chemist's Avatar
The rear shock is bitc* to say the least. What worked for me was picking up a strap wrench. I put a box-end wrench on the top shock mount nut (you've got to crane your arm up and over to reach it), then just used the strap wrench on the shock body to twist the shock off. I had already removed the lower shock nut and knocked it off its seat at that point. I wrecked the dust cover on the old shock in the process, but didn't give a crap since I tossed them in the garbage anyways.
Old Oct 10, 2003 | 03:27 PM
  #32
Gadget's Avatar
Use one of those off set boxed end wrenches and just reach up and put it on the nut. If you end up stripping it, the blue tip wrench works well.
Make sure you coat the new one with antiseize and coat it well.
Gadget
www.GadgetOnline.com
Old Oct 10, 2003 | 04:14 PM
  #33
sschaefer3's Avatar
The stock rear shocks are quite difficult to get off due to the all metal lock nut. Aftermarket shocks use the nylon lock nut and they are easy to get off.
The trick we use on the factory shocks is a 2 person method and works every time.
1. person get under there and hold the 12mm wrench on the nut.
2. One or maybe even two people twist the top of the shock off, the dust cover is welded to the shaft. You'll bust a nut but you'll get them off without using a saw or a tourch.
Old Oct 10, 2003 | 04:21 PM
  #34
AznSky's Avatar
AWESOME! Thanks for the ideas guys!! So most likely I'll bust the nut, and just use the one that came with the rear shock as a replacement? Do I have to anti-seize that one?
Ok last stupid question, I can just use the spare tool inside the truck to get the lug nuts off the wheel? And then use it again to tighten it? Yes, I know this is a really stupid question:pat:
Old Oct 10, 2003 | 04:30 PM
  #35
sschaefer3's Avatar
The guy turning the shock will hurt his testicles.
That would be "busting a nut".
Old Oct 10, 2003 | 04:35 PM
  #36
Cebby's Avatar
Where's the writeup?
Old Oct 10, 2003 | 04:40 PM
  #37
sschaefer3's Avatar
I assume your volunteering to be the model?
Old Oct 10, 2003 | 04:44 PM
  #38
Cebby's Avatar
O U C H ! ! !
Write ups are overrated anyway...
Old Oct 10, 2003 | 04:46 PM
  #39
RTdawgs's Avatar
ill take second dibbs.
my doctor gave me some creme and said everything will clear up in 7-10 days, so i should be as good as new by next week.
Old Oct 10, 2003 | 05:27 PM
  #40
sschaefer3's Avatar
I know one will fit with a really wide lens but I kinda wanted a dude with two.
