Locks always frozen
Old Dec 3, 2007 | 07:01 PM
nermalgod's Avatar
Locks always frozen
I've used the de-icer stuff, WD-40 and Silicone and my locks regularly freeze up on my 2000 Tacoma. I can usually insert the key but the lock doesn't turn. Never an issue in the warmer months but this winter is the worst yet. Is there any reason why this might be happening?
nermal
Old Dec 3, 2007 | 07:07 PM
toy_tek's Avatar
Have you tried just powdered graphite? Clean it out with alcohol and get all the moisture out then shoot some graphite in there.
Old Dec 3, 2007 | 07:22 PM
nermalgod's Avatar
Graphite doesn't work in Wisconsin's Winters. Plus my truck has two inches of ice on it, I can't remove the water, I need to displace it.
Old Dec 3, 2007 | 07:48 PM
b.miller123's Avatar
If it's the actual tumbler (and not the locking part) you could go with some cheapy keyless entry
If your key is really worn out, that will only make it worse
maybe try something thicker to displace the water, like white lithium grease, they've got it in spray cans, and the really thick stuff in cups, just carry a paper towel in your pocket to wipe down your keys for a little bit, and clean it out w/alcohol first
You could get one of those little torch lighters as a last resort, don't feel bad, on my wife's cavalier (which i hate btw) the whole door gets frozen shut, you can unlock it and pull on the handle all day, but all the moisture around the seal gets frozen and it's a PITA the get undone without pouring hot water all over it
second last resort: KY? Astroglide?
Old Dec 3, 2007 | 07:49 PM
BajaRunner's Avatar
You could try moving to a warmer climate?
Old Dec 3, 2007 | 07:50 PM
89macrunner's Avatar
i used to carry a little bottle of alcohol that had a tip to fit inside of the key hole in the door. It worked wonders in the winter time.
god i love arizona
Old Dec 3, 2007 | 08:11 PM
notanymore's Avatar
not everybody likes it being 80 degrees on Christmas
Old Dec 3, 2007 | 11:21 PM
rocket's Avatar
Get a key remade at the dealership via your VIN # and see if that helps.
Old Dec 4, 2007 | 01:28 AM
stormin94's Avatar
Well, you sprayed the WD-40 in there, so that could be a problem. If your locks are frozen with Ice, get one of those pocket torches, and take care of business. And BTW, I would LOVE 80 degrees for Christmas. But I would also love 30 degrees and snow. Just no RAIN.
Old Dec 4, 2007 | 02:39 AM
rocket's Avatar
If all else fails, pull off your interior door panel and take a look at the entire mechanism... It might just need lubricant in places that can't be accessed from the key hole.
ladybugRC
458
Aug 21, 2020 10:41 AM
PNW94Runner
Sep 29, 2015 02:55 PM
toyotasaurus
Sep 24, 2015 03:30 PM
AustinTaco
Sep 18, 2015 08:58 PM
Jason4X4
Sep 17, 2015 08:02 AM
