lights in climate control and clock
Old Oct 16, 2003 | 06:39 AM
4runner4me's Avatar
For some reason on my 1999 limited the clock never works unless I tap it or pull the dash back and unplug it and plug it back up. I was messing with it the other day with my center dash pulled back and when I put it back half of the light in my climate control is not working. It is the digital little screan on 99 up limited. Does this mean my display is gone bad or is it a bulb that can be replaced. It realy sucks because now I dont have a clock and my dash lights are messed up. Can anyone help me!!!!
Old Oct 16, 2003 | 01:00 PM
Toyota Punk's Avatar
I've been working back there on mine recently, and it sounds like you have a loose wire/bad connection. If you had a bad bulb it shouldn't affect the clock. I can't really say anything beyond that because I don't have a LTD. I would check all of the wires and connections behind that part of the dash to make sure they are all secure, tight and going where they are supposed to (although you've probably already done so). Good luck!
80Truck
Oct 12, 2025 07:25 PM
Charecter1
Nov 6, 2023 10:08 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
kirkrunner
Jul 27, 2015 07:59 PM
rushw
Jul 18, 2015 01:46 PM
