Lift and tires for a 92 PU
Old Mar 29, 2004 | 04:36 PM
i want to lift my 92 pickup extended cab, (2wd ) and i would like to put larger tires on it. im not looking to go off roading since the 2wd thing but i want it to look good. how much does a body lift run, how hard is the install and what size tires can you add after the lift, then what type of gas milage decrease is there with a 22re?
thanks
Chris (i did a search but not that good of one)
Old Apr 1, 2004 | 09:10 AM
hello. . tap, tap, tap . . . is this thing on?
Old Apr 1, 2004 | 09:39 AM
Waterboy's Avatar
How big of tires do you want to run? If you went to 31" you could probably still use your stock gears but you'd have to look at regearing with 33". Once we know how big you want to go we can tell you more about your lift options.
Old Apr 1, 2004 | 05:45 PM
prolly 30s, i just want to make the truck look better
Old Apr 5, 2004 | 06:19 AM
Waterboy's Avatar
What size is one there right now? I would think you could fit 30's on there with no lift. The cheapest way to get a little height is to put a body lift on.
http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml
Everyone only has good things to say about Rodger's lifts. You might be able to fit 31's with a 1 or 2 inch body lift.
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
nickbeauregard
12
Aug 7, 2015 06:04 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
coffey50
Jul 28, 2015 10:55 AM
