Lift questions, what to get.
Originally Posted by Dr. Zhivago
Well, the stock spring rate is right around 480Lbs/in. SAW's are 15" long 2.5" diameter 675lbs/in springs now and they when started making them originally they were 14" long 2.5" diameter 600lbs/in. The Downey's are 600lbs/in 14" long 2.5" springs and I don't know about Kings or what Donahoe uses. Donahoe's springs are proprietary and I'm pretty sure Kings use Eibach springs, but I don't know what rate. They are 2.5" diameter, that much I do know. They're probably in the neighborhood of 600-700lbs/in.
What you are doing by fabbing your own coilovers also depends on the intended use for the vehicle, obviously. All the aforementioned coilovers are designed to provide excellent off-road performance while still maintaining a nice on-road ride. In fact, the SAW's plus either the Downey/Bilstein or OME/OME rear options ride WAY better than the truck ever did brand new. The stock setup leaves a lot to be desired.
Hope this helps.
G
EDIT: If I hadn't already bought the SAW's, I would have been willing to prototype a set for you. You're about 2 weeks too late...
Hope this helps.
G
-Dan
The SAW's are $650 plus shipping form Mike @ Xtreme Off-Road to any Yotatech member in good standing. They're at least $700 plus shipping from any other company.
The Downey's are $599 plus shipping to anyone.
The Kings are like, $800-850.
The Donahoe's are $950, including Shipping and the Spanner wrench from Wheeler's Off-Road.
ALL of them use shocks that are re-buildable, re-valveable.
G
PS YW X-AWD
G
PS YW X-AWD
Well, I got the recall stuff done today so I'm ready when you get here Bob. They put in some new rubber pieces but I still have the same coil springs. Sucks, I was hoping for new ones. On the reciept it says they "replaced coil bumpers and added hollow coils." What is a hollow coil? My roomate says the back looks a little higher. I think it might. Anyway, my reason for posting is to figure out what a hollow coil is. Someone has to know.
stu
stu
coffey50
Jul 28, 2015 10:55 AM
