Lift Help
Lift Help
Ok... so I have extended Donahoes and Camberg UCA sitting in the garage waiting to go on so now I just have to decide what to do in the rear. 1998 4runner 1" body lift.
I hate to say but I didn’t get out much to go offroading this past year. Hoping to do more in the new year though.
I cant decide between OME 890 or 901. Both cost the same.
With the 890's I would get 285/75/16 Nitto TG. Then I would possibly need wheel spacers or new wheels. Less gas mileage. Small loss in power.
With the 901's I would more then likely get 265/75/16 Nitto TG/ I wouldn't need new rims or spacers. Would 265/75 look small with 2" lift? I have worn out ones now on stock with only 1" body lift.
Second choice... go with OME shocks or spend a little more for Icon rear shocks.
So people who have these rear set-ups please say if you like it, what you would change, any suggestions, and any help.
lots of folks are running the 890s in the back and they are a good all around spring for our Runners.
The 891 will give you more lift-I run those and got 3" lift in back-but they are too stiff for most folks unless you are running 300 lbs in back on a routine and regular basis. I like em, but likely could have gotten by with 890s.
Read Sonoran Steel website. Wealth of info. Steve knows his 4Runner lifts, and a lot more. I believe he has said the 890s are the only Old Man Emu spring worth buying....
Hope this helps!
justdifferentials
Sep 5, 2015 06:52 PM
joeynational
Sep 5, 2015 01:54 PM
