Leaking rear differential
I swapped the rear axle with a yard donor on my '97 when it blew. You don't have to worry too much about expense in hardware doing the swap. The only thing that might break is the brake lines.
Don't forget Wyoming, 4Runners sit on coils.
So pop the sway bar links, the panhard, the 2 shocks, the driveshaft, the brake lines, and the parking brake cable.
Soak everything down in PB Blaster for a few days and you should be able to pull that rear axle assembly as a unit in about an hour.
Until then, make sure you keep that rear full of fluid and it should last for quite some time. Forget about it, run low and dry, and you'll overheat the bearings and blow up the rear end.
Good to hear that the overall process isn't too bad if I can find a good donor.
It makes sense that the brake lines will need replaced. Since I'm in the rust belt it's going to be a good thing to do regardless.
I'm in college right now so nothing of that magnitude is going to be done until next summer most likely. However, I am fully aware of the consequences that would come with running out of gear oil. I check it frequently and hopefully I can get it sealed completely in the near future. I have new fill and drain plugs as well from Toyota already so no worries of rounding those off.
Hey guys. As you can see the underneath of my 4Runner is pretty rusty. I noticed the other day I've been leaking oil from the rear differential for a while now. I think it's about time I put the 4Runner to rest (because of all the rust) but while I look for something new, I'd like to make sure the oil in the differential is topped off. Can you tell me how to add oil to this thing?
thanks.
jerusry
Oct 19, 2015 05:28 PM
Iceman4193
Jul 15, 2015 04:48 PM
Avenged
Jul 9, 2015 07:55 AM
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
Jul 8, 2015 07:15 PM
