Leaf spring question
Old Jun 26, 2003 | 05:55 PM
oly884's Avatar
Guest
I know that this should go in the off road section, but this also goes for on road too.
I just got some new leaf springs for my truck today. I ordered some skyjacker 4" leafs, problem is they are 6". I thought that I could take out one of the 3 main leafs, the smaller one, and have around 4" of lift, and a lot better articulation. I know that the springs are DESIGNED to have all leafs in it, but is it dangerious at all to do this? thanks, David
Old Jun 26, 2003 | 08:02 PM
oly884's Avatar
Guest
bump
Old Jun 26, 2003 | 08:06 PM
Cebby's Avatar
How did you measure 6"? The weight of the truck should take them down a bit. Can't help you on pulling leaves out of the spring packs.
Old Jun 26, 2003 | 08:07 PM
oly884's Avatar
Guest
I just bought them, and they have the part # that say's they are 6"
Old Jun 26, 2003 | 08:11 PM
Cebby's Avatar
My bad, I thought you were measuring them off the truck.
Old Jun 26, 2003 | 08:13 PM
oly884's Avatar
Guest
Ah, I see, not a problem. I'm mainly just wondering if there is any danger in doing this.
Old Jun 27, 2003 | 05:20 PM
oly884's Avatar
Guest
bump
Old Jun 27, 2003 | 06:21 PM
joez's Avatar
nope, no danger, but it wont lower you truck. it will bring it down about a half and inch, and give a much flexier suspension out back, with a better ride.
if you are going to do this, remove the leaf 2nd from bottom. dont take out a main leaf, these are the strength of the spring. or you could take out the leaf below the mains, that would prolly work better, but might make them a litle too soft
88sasturbotoy
Jan 30, 2026 01:57 PM
nvdesertrunner
May 11, 2020 08:18 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
shisha1999
Sep 21, 2015 08:22 PM
Nickdigg
Jul 7, 2015 06:04 AM
