Knocking Sound
Old Jan 2, 2007 | 09:28 PM
TRDatVT's Avatar
Knocking Sound
Guys, im trying to troubleshoot this issue before i go to the shop tomorrow afternoon. Tonight on my way home my truck starting making a knocking sound. It varies with engine speed not RPM and doesnt begin to get loud enough to hear until around 35 or so. It only knocks when you are on the gas, but immediately after you let off it stops and starts again upon pressing down the gas pedal again. Let me know what you think or if you need more info. It sounds as though its coming for the tranny or there abouts.
Old Jan 2, 2007 | 09:29 PM
Elton's Avatar
check the u-joints
Old Jan 2, 2007 | 09:30 PM
TRDatVT's Avatar
That was one though at my truck has 114K on it and they have never been replaced to my knowlege... Would that be variable on whether or not i press the gas down or not? Does the torque change it enough?
Old Jan 2, 2007 | 09:35 PM
Elton's Avatar
well my last truck i had a u-joint going out and it would do the same thing i had to drive it 200 miles like that good lesson learned
Old Jan 2, 2007 | 09:39 PM
TRDatVT's Avatar
Now that i think about it, i had a buddies pickup that did that a long time ago... Thanks for the insite, what should i look for visually, or am i going to have to take it apart and check them individually?
Old Jan 3, 2007 | 08:50 PM
TRDatVT's Avatar
Just to let you know... the rear end is toast and its time for a truetrac!!!
Old Jan 3, 2007 | 09:49 PM
Elton's Avatar
well that would make some noise guessing it maybe from haveing a s/c ? while your in there maybe regear it ?
Old Jan 3, 2007 | 09:52 PM
Keggo's Avatar
I would agree with Elton. Do all the work you can while it's open. Maybe cryo'd gears as well... stronger. You can rebuild it... you have the technology... You have the capability to build a locked and regeared diff. The rear will be that differential. Better than it was before... Better, Stronger, Faster... SIX MILLION DOLLAR DIFF!
Old Jan 4, 2007 | 11:29 AM
TRDatVT's Avatar
Well it turns out they are replacing it under some sort of warranty claim since they replaced it twice under warranty a while ago... I dont know some crap a buddy who works there helped me swindle into. So i will be getting a nice new stock rear third member, and taking the old one and rebuilding it for bullet-proof, or at least as close as possibly.
Dont think regearing the 4.10 is a good idea with the manual, she runs like a champ as it i think that anything different my hurt performance for me, but i could be wrong. What are the best gears to get and where can i get them? I am planning to use the Timken bearing installation kit as well as a detroit truetrac for an LSD unless someone can convince me otherwise... Bring on the info!
Old Jan 4, 2007 | 03:19 PM
TRDatVT's Avatar
Here are some pics i just took of the unit...(the old third member) ring gear is cooked!
moparbay
Mar 10, 2023 03:50 PM
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
ac7822
Sep 11, 2015 08:49 AM
Streetrod19772000
Sep 10, 2015 06:22 PM
moparbay
Sep 3, 2015 12:48 PM
