Keeps blowing fuses
Old Aug 21, 2005 | 12:32 PM
husker267's Avatar
Keeps blowing fuses
Here's the deal. Managed to hook a battery up backwards on my wifes 98 4-Runner and popped the 100A fuse in the engine compartment. Replaced it and checked all other fuses. Found the 15A dome light popped as well. Upon replacing, it blows right away. Any suggestions on where to check?
As of right now the truck runs, but missing: Dome light, radio, clock (all related to the 15A), alarm, and power locks. Unfortunately, the wiring diagrams in the Haynes manual leaves much to be desired. Any suggestions are appriciated.
Old Aug 21, 2005 | 01:37 PM
Beartracker's Avatar
Disconnect the battery again and let it sit a few minutes.Then replace all the fuses first and then hook the battery back up and see what happens.
Old Aug 21, 2005 | 06:39 PM
Skitz's Avatar
U may have also popped/shorted a wire along the way...
Find someone good with a meter to trace it...
Good luck.. I had a similiar problem with a chevy... I had to rip open the dash to find a torn wire shorting to ground...
Old Aug 23, 2005 | 10:05 AM
husker267's Avatar
Thanks for the feedack. Beartracker - I tried disconnecting the battery and then replacing. As soon as I reconnected the battery, it popped. Looks like I'll be trying to track down the shorted wire per Skitz.
Now just where to start?
Old Aug 23, 2005 | 10:59 AM
husker267's Avatar
I looked through the Haynes book again. I'll start with the Integration Relay, but I have no idea where it is physically. There is a notation bedside the icon for the relay of J/B 1. Any ideas?
puddlepirate
Jul 30, 2016 06:29 PM
4banginRunner
Nov 13, 2015 05:23 AM
bryan34w
12
Sep 30, 2015 02:50 PM
Scotttekoch
Sep 28, 2015 10:30 PM
JPV
Sep 28, 2015 03:15 PM
