ISR Mod - Mid-grade fuel without ping
Old 01-08-2004, 05:41 PM
rimpainter.com's Avatar
Exclamation ISR Mod - Mid-grade fuel without ping
After running nearly a year on premium fuel due to the pinging I experienced on regular with the ISR mod, I decided to split the difference and run midgrade. I should have tried this a long time ago.
After 3 tanks of fuel, I am happy to report no pinging under all conditions. Lugging it, smoking ricers, hill-climbing, etc. All yielded no ping with 89 octane.
My mods are in my sig. If you are running a similar set-up and haven't tried the "run the lowest octane you can without pinging" method - please do. It just might save you a lot of money over the next year.
BTW: I reduced the size of the FPR vacuum line - back to the stock size. In doing so, I had to reduce the FPR barbed hose fitting slightly. This only applies to the 96 - 98 5VZ's. Just go to Home Depot and pick out the next smallest barbed fitting, while maintaining the same thread diameter.
Later.
Old 01-08-2004, 06:53 PM
Tacoma Dude's Avatar
Ooh, thanks for the update!
I'm not sure what pinging sounds like - whether or not it's a quiet or obvious sound so I removed the mod for now.
When someone else can verify whether or not I got pinging I'll put it back in as I am missing some of the additional oomph :cry:
Tacoma1313
08-17-2015 05:44 PM
Hiluxtrucha
07-22-2015 10:00 AM
Massmayhem247
07-18-2015 05:46 AM
icentropy
07-11-2015 07:21 AM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: ISR Mod - Mid-grade fuel without ping
