Intermittent starting on 3rd gen
Old Nov 21, 2005 | 05:43 AM
snap-on's Avatar
nother vote for starter contacts. I let mine go for WAY WAY to long, and durring its long long death that was one of the stages.
Old Nov 21, 2005 | 05:44 AM
Originally Posted by FilthyRich
My wife's 99 SR5 has 99k miles. Is up to date on ALL service work. It has not been wheeled in a long time--no mud or anything.
It currently has a 3 year old Interstate battery. However, the last week when you go to start it--nothing. THe lights work, but nothing. Not turning over, no click of the starter. Do that about 3-4 times and it starts. OR other times it will not start right up, like the battery is not fully charged.
I have not had the battery tested.
I was wondering if anyone else has ever experienced the same issue
This is classic symptom of bad starter contacts. You can get them for about $5.00 from any starters repair shop. If you want to save money do not get a new starter- just replace a contacts. Hardest part is getting starter out but I have heard that some people were able to change those contacts without completely removing starter form the truck.
Good Luck!
Old Nov 21, 2005 | 05:53 AM
FilthyRich's Avatar
Ok seems like the contacts are the problem. Time to test the battery, inspect all fuses, battery terminals and pull the starter. Of course it is raining today
Old Nov 21, 2005 | 05:59 AM
bamachem's Avatar
you may not have to pull the starter. get underneath and get your hands on the contacts. they may be loose like mine were. a good cleaning and retightening and they may be fine.
Old Nov 21, 2005 | 06:02 AM
  #25
rimpainter.com's Avatar
FWIW, starter contacts from Roger took me 1-hour total to install. I have a 1" BL though; I hear it is more difficult to pull a starter on a non-body lifted Runner.
My 96 had the exact same issue (only it would click once when the ignition was turned to "START." Repeated ON --> START --> ON --> START combinations would eventually start it.
When I pulled the old contacts, I could clearly see the problem. $20 job.
Old Nov 21, 2005 | 06:23 AM
  #26
midiwall's Avatar
Eric, something else to try in the meantime... When mine "does this", I found that if I hold the key in the START position for a few seconds, it will eventually turn over. That's not healthy though - what's happening is that you're running current through the contacts without the starter turning and that'll cause a good bit of heat to generated.
Jun 1, 2021 01:51 PM
colinmil
Jul 6, 2015 04:03 PM
Steezy96yota
Jul 6, 2015 10:00 AM
karbin
Jul 5, 2015 11:37 PM
HRDC0R19
Jul 5, 2015 06:43 PM
