interior lights went out
Old Jan 29, 2003 | 03:21 PM
doink's Avatar
hey guys. on way back from hifi buys today, i noticed that the A/C controls didnt light up. has anyone had a problem with this? could i just go to toyota and the could fix it for me?
Old Jan 29, 2003 | 04:13 PM
Corey's Avatar
Co-Founder/Administrator
Is it just the air-con light, or your heater controls too?
If it's the heater controls, on my website under the Tips & Tricks section is how to fix it.
Also to get too the air-con light, follow the info on my page.
Once that panel is off where the heater controls are, you can pop out the air-con switch to get too the bulb.
Old Jan 29, 2003 | 05:00 PM
doink's Avatar
thanks corey. one question.about..
pull off the heater knobs and take a tool, even a paper clip will work. You stick it in behind the black plastic panel that normally lights up and gently pull on the sides and it will pop off
do i stick it in where the knobs would normally slide back and forth?
Old Jan 29, 2003 | 06:39 PM
Corey's Avatar
That's a big 10-4.
It would be better to work from each side instead of the middle of the panel.
That way it won't flex as much, and posibly crack it.
I keep that same paper clip in the ash tray for just such an emergency if I need to pull it again for some reason.
Old Jan 29, 2003 | 10:19 PM
UKMyers's Avatar
Doink yes start on the far side closest the passenger seat. It will be a PITA for sure especially if it's never been off before. There are several places that hold it on but if you can that one side going your golden. Take is slow and dont' break anything...
Jun 1, 2021 01:51 PM
AkitaDog
Sep 1, 2015 08:05 AM
mr_manny
Jul 31, 2015 10:39 AM
TDonkey
Jul 26, 2015 10:14 AM
GeoRoss
Jul 24, 2015 03:03 PM
