Interior lights don't work, won't start!!! 98 4runner
Old Dec 17, 2004 | 04:44 AM
joshd's Avatar
Help!!! I left my light on in my 98 4runner limited and the battery went dead, so I went to jumpstart the truck and when I hooked up the jumpercables the alarm proceeded to go off. Now when I attempt to start the truck none of the dash lights will go on, power windows will not work, dome lights etc. but the exterior lights will work. Did I blow a fuse or something. Someone please help!!!!
Thanks in advance
Josh
joshd's Avatar
Oh....one more thing, the truck will not start!
Old Dec 17, 2004 | 05:09 AM
MTL_4runner's Avatar
Did you hook it up reverse polarity or something?
Do you get any lights at all on the inside when you jump it?
You might try a trickle charger on the battery and check all the fuses to ensure none are blown (both under the dash and in the engine compartment).
Old Dec 17, 2004 | 05:35 AM
joshd's Avatar
The battery was hooked up (jumped) correctly, No lights at all in the interior. horn does work. I don't have the remotes for the factory alarm...Would that have anyting to do with it?
Thanks
Josh
Old Dec 17, 2004 | 05:40 AM
Thanks
Josh
If you don't have the remotes that could certainly be a problem.
I would remove the alarm (not that hard to take out) or get new remotes programmed for it.
You might ask the dealer if you drained the battery like you did, would it prevent starting?
I am not sure since I have never tried it myself but I know the viper I have will go off and prevent starting without using the remote.
Old Dec 17, 2004 | 05:59 AM
4Hummer's Avatar
Yeah sounds like your alarm has starter disable. The alarm may have a Valet switch. which Should let you start it ???
Old Dec 17, 2004 | 06:16 AM
WT's Avatar
WT
Thanks
Josh
My bet is that the factory alarm has disbled your starter and since you don't have the remotes to turn off the alarm the alarm thinks it should disable your starter. May want to just unplug the brain (under drivers seat) and see if it will start after that.
Old Dec 17, 2004 | 06:20 AM
joshd's Avatar
Thanks for the quick reply guys! I will try to unplug the alarm unit, but does it make sence that the interior electronics will not work? Is there some kink of main fuse that it could be? Thanks again.
Old Dec 17, 2004 | 06:26 AM
WT's Avatar
WT
The alarm could also be disabling that stuff to especially the power locks..
worth a try to unplug the brain first and see if it helps any.
Jdgarrison
Oct 1, 2015 05:22 PM
newzingo
Jun 24, 2015 01:50 PM
paxanders
Jun 21, 2015 06:29 AM
ShaunKris
Jun 17, 2015 04:33 PM
