Intalling new bushings
Old Feb 18, 2003 | 03:29 PM
DavidO06's Avatar
Hey, i finally ordered and recieved my energy suspension bushings for my factory sway bar. Has anyone else installed them. The factory hole is slightly offset and i didn't know if it would cause a problem with the new bracket. What kind of nuts and bolts did you guys use if you did this mod? I am about to work on it some more, i have just looked at it right now.
Old Feb 18, 2003 | 03:42 PM
Dr. Zhivago's Avatar
Away
Yeah, I bought new nuts, bolts and washers for the sway bar brackets that came with the ES bushings. You will need to grind one side of the washers for the bolts that hold the rear sway bar. I used new nuts, bolts and washers for the front. Check jalaber's site for a write up.
Hope this helps.
Dr. Z
kawazx636
Oct 6, 2021 03:03 PM
live4soccer7
May 11, 2016 06:52 PM
punks_is_4x4
Feb 26, 2016 04:29 PM
JRB4Runner2015
Sep 20, 2015 12:29 AM
Pocoyota
Sep 8, 2015 02:41 PM
