installing spark plugs on 2002 3.4 v6 tacoma
Old Feb 9, 2007 | 06:07 AM
mkgarrison5's Avatar
hey guys what are some things to look for in changing the spark plugs in a 2002 3.4v6 tacoma? one side has the elect coils and the other is just wires. i know i have to take off the air intake tube just to get to one plug but as for the coils what do i need to look out for? thanks guys
mike
Old Feb 9, 2007 | 06:25 AM
MTL_4runner's Avatar
Here's a good writeup for you on changing the plugs:
http://www.4x4wire.com/toyota/mainte...ep3.html#plugs
......you might want to look at the other 4 pages of maintenance items as well.
Old Feb 9, 2007 | 07:23 AM
on the side with the coils, when you take the coil off, are there plug boots under it? never done it before. thanks guys
Old Feb 9, 2007 | 08:01 AM
Elton's Avatar
real easy to do just take a 10mm wrench undo the bolts on the coil pull it up then grab a long extension and use a spark plug socket remove the old plug and when putting the new ones in just get it started with the spark plug socket then remove it and swap it for a regular metric socket
Old Feb 9, 2007 | 08:51 AM
Originally Posted by Elton
real easy to do just take a 10mm wrench undo the to bolts on the coil pull it up theb grab a long extension and use a spark plug socket remove the old plug and when putting the new ones in just get it started with the spark plug socket then remove it and swap it for a regular metric socket
ok thanks...
Old Feb 9, 2007 | 10:12 AM
Elton's Avatar
make sure you use ngk or denso dual ground plugs i frogot to say you need to use a deep metric socket
4x4YOTA
Aug 23, 2016 09:08 AM
G-off
Dec 29, 2015 12:44 PM
Sam hain
19
Sep 30, 2015 08:25 AM
Toys4parts
Sep 26, 2015 01:56 PM
Dparr2ndgen
Sep 8, 2015 01:06 PM
