Installing 99 roof console, need help
Old 05-31-2007, 11:02 AM
saulgoode's Avatar
Hey fellas need a little advice,
I'm switching out my rear view mirror console out of my 98 for a console from a 99, I'm getting no power to the map lights. I tried testing the power wire with a voltmeter to make sure it was getting power but I got no voltage, I did this with the truck turned on and off. The sunroof switches work just fine. Any ideas would help out. Thanks.
Old 05-31-2007, 11:47 AM
BajaRunner's Avatar
The most common problem is a bad ground. Make sure that you have completed a circuit, otherwise charges (electricity) will not flow! Trace the wire back, and make sure that it is spliced to a hot wire. Check the hot wire with a volt meter first. Recheck connections.
Old 05-31-2007, 06:40 PM
saulgoode's Avatar
got it figured it out, I didn't have a good enough ground. Figured this out the hard way and blew the fuse. Oops! Got lights now!
icentropy
09-16-2020 02:47 PM
BeMiceElf
10-10-2015 09:40 PM
terminator
07-27-2015 07:13 PM
TDonkey
07-26-2015 10:14 AM
HaydenConQueso
07-12-2015 05:22 PM
Quick Reply: Installing 99 roof console, need help
