Installation of Goodridge Stainless Steel Brake Lines
Old May 7, 2006 | 03:39 PM
DoubleZero4x4's Avatar
Today I installed my Goodridge SS Brake lines on my 3rd Gen. The stuff you will need is pretty simple and most of us already have these tools...
1 - Set of Goodridge SS brake lines (part # 21183)
1 - 10mm Open End Wrench
1 - 13mm Open End Wrench
1 - 17mm Open End Wrench
1 - flathead screwdriver
1 - pair vice grips
1 - Brake Bleeding kit (I use a vacuum pump one - $30 at Autozone)
1 - Large bottle of new brake fluid
1 - set of wheel removal stuff (jack, jack stands, lug wrench, etc)
First you should probably drop your spare. Trust me, I didn't do this and I wished I had. Next open up your hood and remove the cap to your brake resovoir. Open up the new bottle of brake fluid and have it standing by to top off your resovoir as needed.
Next loosen your front lug nuts and then jack up the front of your truck using your favorite bottle or floor jack and support the vehicle on jack stands and remove both front wheels. With the wheels off you now have access to your brake lines.
Don't yet remove the retaining clips that hold the brake lines to the body and the wheel assembly. Next loosen the brake lines and remove the upper connection (closest to the body) first. Use the finger of a latex glove to cap off the line lest you will have fluid dripping. Remove the lower connector (closest to the caliper) and now you can remove the retaining clips and remove your old brake line. Once the old line is out install the new line and install the retaining clips. Re-attach the lower connection and then re-attach the upper connection.
Once these are re-attached, hook up your brake bleeding kit and pump it up. Once you have a vacuum loosen up the bleeder valve and drain out about 3oz of fluid. Be sure to keep a vacuum the whole time including when you tighten the bleeder valve. Top off your brake resovoir and repeat the bleeding process again draining out about another 3oz of fluid.
Repeat the last 2 paragraphs for the other wheel.
For the rear you will have to loosen the top connection to the brake line first because the brake line screws into the mount at the differential; the line must be free to loosen and tighten it. With the top connection off, you can cap off the line and remove the body side retaining clip. Here is where it gets tricky...
You will need the 17mm wrench to loosen the lower part of the brake line and now you can unscrew it. When you get the brake line off you will need to retrieve a C-clip off the top part of the old brake line and attach it to top mounting point of the new brake line. The C-clip will keep the new line from pushing through. Now you will attach the differential side of the new brake line and tighten it down with your 13mm wrench. Yes - its a smaller wrench for the Goodridge lines. Once its tight you can now attach the upper part of the brake line. Re-attach the body side retaining clip and now re-attach the hard brake line.
With the brake lines re-attached you should now bleed the rear wheels as well. Hook up your brake bleeding kit and pump it up. Once you have a vacuum loosen up the bleeder valve and drain out about 3oz of fluid. Be sure to keep a vacuum the whole time including when you tighten the bleeder valve. Top off your brake resovoir and repeat the bleeding process again draining out about another 3oz of fluid.
If you are so inclined just repeat this step on all the wheels until the fluid is clear and now you have just flushed your brake system.
You should now be done - put your front wheels on, torque them down. Put the spare back and enjoy your new Goodridge Stainless Steel Brake Lines.
The Pro's: It does seem to me that the pedal has a bit more stiffness to it. The pedal travel is about the same but with the Tundra upgrade I did last weekend my brakes are a dream now.
The Cons: I hate messes made with brake fluid. Fluid will drip, get used to it. This was an all around easy mod.
Overall: I would rate this at a 2.5 out of 5 on the difficulty scale and 3 out of 5 on the "cool mod" level. In other words I don't regret doing the mod.
Old May 7, 2006 | 04:18 PM
rimpainter.com's Avatar
Cool! Can you post where to get these lines? You posted a part number, but I didn't see a place.
Thanks.
Old May 7, 2006 | 05:12 PM
Hoerr Racing Products (hrpworld.com). Irv Hoerr is the owner (an uncle by marriage). A lot of racing in the family (Irv had 3 Winston Cup Start's and spent most of his time GT racing Trans Am's). Great communication and a great staff.
I ordered the lines, they weren't in stock so they called me the next day told me there would be a 48 hour delay and really kept me in the loop.
Old May 7, 2006 | 05:52 PM
ebelen1's Avatar
Goodridge are supposed to be the better brake lines we can get for our trucks but many have the all-pro off road lines. Anyone have a preference?
Any reason you chose goodridge over others? I want to have this mod done too but got a good deal on some all-pro rears so I thought I would get the fronts to match.
Old May 7, 2006 | 05:56 PM
914runner's Avatar
Goodrich is a big name in racing and have been around for a long time. I would trust them in my brake system wayyyy before I would ever trust all-pro.
Old May 7, 2006 | 06:57 PM
I chose the Goodridge lines on a reccomendation from Gadget and from a friend who put them in a rice rocket.
Old Nov 6, 2006 | 08:24 PM
maguirre's Avatar
I also ordered this kit from hrpworld.com. The only issue is that I ONLY got the (3) lines. I thought i was going to receive clips/washers, etc. It seems that something was not sent to me. These are lines I got.
Please let me know if I should of gotten something else.
thxs,
maguirre
00' SR5, 5spd
p.s. sorry for the small pic
Old Nov 8, 2006 | 07:24 AM
Thats all you need. Having done this twice now (once for me and once for the wife) you will re-use the retaining clips that hold the soft-line connections to the hard-line connections.
As for the three lines, there is only one line going to the rear wheels and that is located just above the Rear Differential.
Old Nov 8, 2006 | 02:02 PM
maguirre's Avatar
thank you,....
I ordered a brake line kit for my supra and it came with all these little clips and washers... I just thought there was something missing with my 4runner kit.
maguirre
00' SR5, 5spd
Old Jan 23, 2007 | 11:00 AM
kevin444's Avatar
I just placed my order for the lines from hrpworld! . I gotta say wow there customer service is awesome! They were able to drop shipping cost on me. And have me pick it up from goodridge company itself located in torrance, ca.
Cant wait to put these on.
Old Jan 30, 2007 | 06:48 PM
kevin444's Avatar
i highly recommend buying from hrpworld cheapest online!!! great service, just got my lines installed.
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
87turboPA
Jul 12, 2015 07:49 AM
crashburnoveride
Jul 10, 2015 06:39 AM
87turboPA
Jul 9, 2015 05:58 AM
