inner tie rod
inner tie rod
Have to first say thank you for all the great posts about repairs and mods. It has made repairs much easier.
I am just about finished with replacing a CV, tie rods, steering rack bushings, Sway bar kit and links for the front.
Just have a couple of questions. Cannot find how tight to get the inner tie rod to the steering rack. Any thread lock on the jam nut? Also, what should I use to top off the front diff.?
Thread locker is a good idea on the inner thread...Get the inner rod as tight as you can by hand with big wrench/cresent wrench(no cheater bars)..the old retaining washer needs to be flattened out and then "peined-over" the inner rod flats...this keeps the inner from ever becomming loose...Install boot and don't forget to either replace clamps or use steel zip ties..or hose clamps...If dirt gets onto inner shaft it could hurt the rack seal=leak=new rack....
From: Shelburne, VT previous: Everett, WA; Bellingham, WA
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
