Increasing Gas Mileage?
Old Oct 20, 2004 | 08:25 PM
pfbmgd's Avatar
Buy a 2.7lL 4Runner like mine . For the last 11 months that I have kept track I get 24 mpg . I would say I drive 75% highway .
Old Oct 21, 2004 | 12:11 PM
jwahaus's Avatar
I can confirm that tire size makes a difference. I just replaced my 31's
with 32's and it cost me 1.5 MPG. Now I get 17 MPG on average instead
of the 18.5 I was getting with the 1" smaller tires. Well, more like 1.5" larger
tires when you consider 31's had no tread left on them when I replaced them.
Old Oct 21, 2004 | 12:23 PM
kickaha's Avatar
Jwahaus, you might be getting a little bit better mileage than you think, depending on how you're calculating mileage. Going from 31" tires to 32" tires will throw off your odometer. If you're reading 400 miles to a tank, you're probably getting more like 412 miles to a tank.
Old Oct 21, 2004 | 04:03 PM
Tubb's Avatar
The cheapest way I have found to increase gas mileage is to slow down, if you can do it without getting killed by other drivers. Find a semi going close to the speed you can live with and follow him. I'm not recommending drafting.
Old Oct 21, 2004 | 05:43 PM
  #25
kevin444's Avatar
i second tghat just coast and follow a smooth mover. And stay on the right lane.
Old Oct 22, 2004 | 06:14 PM
  #26
Tubb's Avatar
I use the "right lane" for sure, that way I have an escape route when those passing quickly, crash, bounce off of things and flip over.
Old Oct 22, 2004 | 09:59 PM
  #27
Hilux Surf's Avatar
Hybridize your Runner
How about increasing MPG while enhancing performance at the same time? This is a retrofit hybrid electrocharger that is to be re-introduced again this year at SEMA:
http://www.sigmaautomotive.com/elect...trocharger.php
If the rumour is right, BMW is experimenting this with their X5 too.
Hilux Surf
Old Oct 23, 2004 | 07:20 AM
  #28
4RUNR's Avatar
Guest
Route your air conditioning to the intake manifold.
That's like a cold air intake and turbo all-in-one. Low setting is 5hp, medium 50hp, and on high 500hp. But you'll need to put a deckplate on the A/C unit.
he's gone
7
Dec 3, 2019 07:08 AM
accuracy
Aug 30, 2015 09:47 PM
raptor510
Aug 19, 2015 02:15 PM
Tacoma1313
Aug 17, 2015 05:44 PM
nonstop
7
Aug 11, 2015 09:26 AM
