Ignition Key Sometimes Fails to Release
A new issue just starting coming up intermittently. Every now and then, the ignition doesn’t want to go all the way to the “Off” position when I shut off the vehicle. It will stay locked in “Accessory”. I have to shift from park to drive, sometimes three or four times, and it eventually releases. So how do I troubleshoot the safety switch?
I see this is an older post, but this is how I took care of this on my truck.
My 2002 4Runner was having an issue similar to this, having to fiddle with the shifter (into to park, out of park, etc.). The shift lever also had a fair bit of lateral play in the handle. I found the bushings in the selector lever were worn causing the problem. It was an expensive fix totaling just under $10 in parts. Part #9038511003 https://parts.toyota.com/p/Toyota_20...038511003.html that I was able to get from my local dealer. A little bit of time removing the shifter and replacing the bushing and I have not had the key get locked in the ignition switch since. The shift lever also feels higher also.
knockerjoe
32
Oct 9, 2014 11:19 AM
txrider
Dec 8, 2009 10:02 AM
