ignition coil OHM Readings... 97 4runner 3.4 V6
Old Jan 12, 2008 | 01:31 PM
afonda's Avatar
I am getting a cylinder misfire code for cylinder 4 and 5. as well as a random misfire code for all cylinders...
I checked the OHM reading on the ignition coils. They are all reading at 1.3 OHM's. The book indicates that the normal range should be 0.6 to 1.05 OHM's.
I find it odd that all the coils read identical yet most of the time the engine runs fine.
I do get a rough idle when the engine is cold and especially under heavy acceleration.
Can anyone confirm what the correct or acceptable OHM's reading should be? and if this could be causing the misfire???
Old Jan 13, 2008 | 01:43 PM
afonda's Avatar
come on guys... I really need some help.
Old Jan 13, 2008 | 08:54 PM
86tuning's Avatar
You've checked your plugs already? What brand plugs? How old? How many miles on the truck? What year were the ignition wires made (it's inked on each wire)?
When coils fail on those trucks, it will be a pair of cylinders that misfire, and the codes are almost always stored in memory.
Old Jan 14, 2008 | 07:44 AM
MTL_4runner's Avatar
So you got codes P0300, P0304 and P0305
You need to check primary and secondary resistences, not just primary as you did.
Primary = 0.67 - 1.05 ohms (You may have a bad multi meter if all read the same)
Secondary = 9.3k - 16k ohms
Due to the fact that you have a random misfire and cyls 4 & 5 are not connected, I doubt it is a coil pack issue.
What have you done or had done to the vehicle lately? Maintenance (timing belt)? Mileage?
Always helps to ask first since it helps to have the history when diagnosing.
smthwsn357
May 1, 2024 07:28 AM
MO transplant
Apr 23, 2023 11:58 AM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
msane99
Jul 11, 2015 08:08 PM
Vargntucson
Jul 4, 2015 12:15 PM
