Idle Surge question
Old Mar 18, 2004 | 12:14 PM
silverCRXTC's Avatar
yeah but a m/c is cheeper than a booster
Old Mar 18, 2004 | 07:27 PM
Mr.Spock's Avatar
Look at this link,some helpful information.
http://www.geocities.com/toyotashawn/bizzareidle.html
Old Apr 30, 2004 | 06:59 PM
scorpion34668's Avatar
Originally Posted by silverCRXTC
Ill try this later, you let the truck warm then kill it and then start it and let it idle then adjust it right?
my 92 did this same thig,,the prob was the idle/air control when for the a/c,,even if a/c is not on its is tied into booster vac line
Old May 1, 2004 | 05:29 PM
Mikey's Avatar
Originally Posted by <96 Runner>
Are you sure there is not a miss in all cases? Take a dollar bill, hold it tight about 1/2 inch off the tailpipe, and listen for a loud pop. If the bill get's popped, then you have a miss no matter what.
I just dont see how a brake booster could cause a miss. A miss is almost always timing related. Plugs, wires, timing...that would be my next check.
I never heard that before about the dollar bill. That's a good trick.
Old May 1, 2004 | 05:55 PM
  #25
Waterboy's Avatar
The funkie idle is a very common problem with the 22RE. My dad had the same problem ('94 22RE), he replaced the TPS and it fixed it. He chased the problem around for a few years before he found out what it was. Now he gets better mileage too.
Old May 1, 2004 | 07:13 PM
  #26
bike4miles's Avatar
Exclamation
Alright, I have delt with this problem quite a lot and have spent nearly a grand chasing it down over the coarse of a year so I will describe my situation and what I found out.
First of all, the surging idle is caused from too high of an idle speed. In my case, My idle was at 1000 and the screw was all the way down whch means there is a vacume leak someware. I know that now but when I first started messing with this problem I thought it was electrical because when I took out the break light fues, it stoped. For that reason I blew $150 on a used computer.
The next thing I thought it could be after talking to a mechanic was the air flow regulator on the air filter box. After he opend it up and screwed with the spring, it hardly ran at all (DON'T EVER MESS WITH THE AIR FLOW BOX SETTING! IT CONTROLS THE FULE MIXTURE AND IS PERFECTLY SET FROM THE FACTORY) There goes another $150 to replace that.
After replacing a ton of other stuff I don't remember right now, I broke down and left it with the best toy wrench in town (I always do everything myself). He thought it was the wax valve. In the process of replacing it, he noticed the butterfly in the trotle body was worn around the rim so it was not able to close compleetly. He replaced it and that was it. It ran perfectly after that.
The moral of the story: check for vacume leaks in every conceveable place you know and you will probably find the problem. It is NOT elcectrical.
Old Oct 28, 2004 | 02:38 PM
  #27
Yamaha+Toyota=Fun's Avatar
This exact same thing happened to me this week, just started. But i have always had a high idle. I can figure it out!!!!!
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
luckypig44
Jul 19, 2015 11:25 AM
kyletbert
Jul 17, 2015 11:39 AM
