Identifying mystery 3rd member
OK, need your guys help - have a 99 4 runner SR5 4 cyl that had a howling rear end - went to order bearings, the dealership said the VIN indicated a diff lock which it did not have - finally got the right bearing set from a jobber (BK TV6) and got it all together and discovered now that howl gone, I had a clicking. Pulling apart again, I discovered the side gear thrust washers needed to jump a couple sizes to get rid of backlash which was causing the clicking by the spider gears moving towards centre (have I lost you yet?) The manual I have indicates 5 sizes of shims, I have the 0.039 and it appears I need 0.047 to remove slack. Again calling a jobber to order shims, they say there is only one shim for that year rear end and its 1.6 mm (I need 1.2) Question is what do I have in order to track down shims? Previous owner was a Toyota mechanic so I assume the original crapped out and he stuffed in something he had kicking around. Thanks for any help.
Neil
Neil
Um...you can order the parts online from an OEM parts distributor. I just checked one of them, and they have all 5 sizes available(.9,1.0,1.1,1.2,1.3).
The part number for the 1.2mm size is 41361-35340.
PS, way to go on that thread title...identifying mystery 3rd member...WTF?
Thanks Mudhippy - googled part number and a couple OEM suppliers popped up - cheap too - might order a couple sizes and test for fit. (will also punch in my VIN to see if matches) Why the jobber was getting bad info escapes me. OK, I have had a 0 to 60 learning curve on rebuilding diffs and lots of references to third member. What exactly is the third member - the diff? the axle? Some guy exposed to too much radiation?
lol... the 3rd is the diff, they call it a 3rd member because its a whole unit, unlike chevy and ford, you dont pull the back cover, and pull the parts out that way, instead, u simply pull the axles, then unbolt the 3rd from the front, and slide it out, then tear into it on a bench.
