I need some info on how to fix this
hey there all i have a 94 toyota pickup 4WD my question is sometimes when i idle it will start to rev itself up and down without me giving it any gas...now is this normal or do i need to fix something and if so...what? thanks for the help
I had the same exact problem with my Runner a couple of months ago. It got to the point where it would jump up and down so bad that it would drive me crazy; not to mention feeling like it was going to stall on me at times. What my mechanic and I did was adjust the valves; over time they had gotten very stiff and weren't opening and closing as precisely as they should be. This cured the problem instantly and the truck idles perfectly.
Definitely check the vac lines first, and if that seems to be fine you may want to look into this.
Good Luck
Good Luck
the1998sr5
15
Jul 14, 2020 08:35 PM
crammit442
7
Nov 29, 2017 12:30 PM
94ofCanada
Aug 14, 2015 06:37 AM
