I must be a retard
Old Feb 23, 2003 | 03:00 PM
Yochdog's Avatar
I must be a retard
Ok, once again I am seeking the wisdom of the forum.
I am back on the fence about suspension options, and now I am wondering if I can just install the OME comfort shocks all around to achieve the desired ride I want. If I can do this, I am still left with the problem of towing. I want to trailer my boat better, so I need firmer springs, I just dont know if I want 2.5 inches of lift.
Bottom line: What can I do to maybe raise the rear a bit for better towing, keep my stock height mainly intact, but greatly increase comfort and rideability?
THanks for the help....
Old Feb 23, 2003 | 04:15 PM
phong's Avatar
Just install some adjustable air bags. Inflate them when towing to level the truck, and then deflate them when not towing.
Old Feb 23, 2003 | 04:21 PM
gwhayduke's Avatar
You might try adding some air springs. They're air bags you install either inside the springs or near them. You can run a minimal pressure in them most of the time, then when you hitch up to tow, air them up to assist your springs and correct the ride height. I've seen them in NWOR's catalog under two different brands: Firestone & Air Lift.
Your comfort shocks probably won't be stiff enough to control motion. You might try the Edelbrocks. They're the only ones that owners have claimed they have smoothed out their ride while controlling the motion without riding like a rock.
I have Gabriels and I definitely would not recommend them as a comfort shock.
Old Feb 23, 2003 | 05:44 PM
jx94148's Avatar
There also are air shocks out there. You can adjust the pressure just like air helper springs. I'm not sure who makes them though.
Old Feb 23, 2003 | 07:38 PM
2wheeler97's Avatar
Performance products has some air lift suspension stuff, check there, www.performanceproducts.com I know they have some stuff, can't tell prices or what, but check it out for yourself.
rubrsidedwn
Jul 7, 2016 07:28 PM
seab1209
Sep 3, 2015 05:41 PM
Alex Bessinger
Sep 3, 2015 12:23 PM
juicyfruity
May 2, 2003 07:50 AM
DH6twinotter
16
Apr 5, 2003 09:41 PM
