How much is too much?
Old Dec 19, 2007 | 07:31 AM
jminz's Avatar
All great info, thanks guys.
Old Dec 19, 2007 | 07:43 AM
pkt1213's Avatar
[QUOTE=cackalak han;50699032]Aren't you trying to sell your rig? QUOTE]
I guess I need to change that. It didn't sell so I am selling my other cars I guess. I kinda needed the money but whatever. I'm hoping Santa will be goot ot me and I can def. keep it.
Old Dec 19, 2007 | 01:35 PM
Adam F's Avatar
Originally Posted by cackalak han
BLESS Toyota for making the brake pads so easy to change. Literally, pull a couple of pins, clip, pull out old pad, slide in new ones, put clip, pins back in. Done. 10 minutes per side. That's with taking the wheel off (would be 5 min. with air tools).
Dont forget the extra 5 minutes it takes to push the pistons back in so you can fit the thicker pads.
Old Dec 19, 2007 | 01:38 PM
Adam F's Avatar
Originally Posted by HOOLIGAN 4 LIFE
Do you have a 4x4 or 4x2. I only ask cause if your doing the rotors you might as well replace the wheel bearings. It might not matter weather its 4x4 or 4x2.Butif your down there might as well get it done. Bearings w/ races ran me about $75 for timiken brand. Rotors were about $28-$30 a peice at autozone. Brakes were about $35 also auto zone. I just did the work my self saved me that extra $400 +. As for your axle seal, how much time are you willing to put into it.
You have a 94 4Runner. A 2nd gen. Totally different setup. This is the 3rd gen 4Runner forum. 3rd gen 4Runners have sealed wheel bearings and different style rotors. The wheel bearings have to be pressed on and off. Not as easy as the old style tapered wheel bearings.
Old Dec 19, 2007 | 01:47 PM
  #25
cackalak han's Avatar
Actually, it didn't take me long at all. All that was required was pliers and about 1-2 good squeezes and they were pushed back (duct taped the pliers so as to not damage the pistons). Make sure your MBC is open.
Old Dec 19, 2007 | 03:14 PM
  #26
CASTAIC 4RUNNER's Avatar
im getting mine done for 700 but im getting the waterpump and timing belt also plus everything is from toyota parts!
Old Dec 21, 2007 | 11:34 AM
  #27
mikgrail3's Avatar
Something to keep in mind, if the seals have been leaking long enough or are leaking bad, your rear shoes will be soaked with gear oil. They will need replacing, too. I helped out replacing the seals on mine and the shoes were completely ruined. I bought rear brakes before the seal replacement just in case.
Helping the mechanic after hours, I had both rear seals and brakes done for $220 out the door.
