How many trim packers can I use?
Old Dec 8, 2004 | 07:54 AM
HaveBlue's Avatar
Hey, all-
Yesterday, I went out and remeasured all four corners. The driver side sits lower than the passenger side. I know this is common with lifts, but, these are Tundra coils. I thought for sure the Tundra coils would solve that issue.
I'm using Tundra coils and 1" Cornfed spacers. The driver's side sits 1" lower than the passenger's side. Can I use OME trim packers on a Cornfed spacer? How many can I safely use? If they are 5mm each, I'll need 4 to level 'er out.
Old Dec 8, 2004 | 08:13 AM
Bratik's Avatar
Originally Posted by HaveBlue
Hey, all-
ARB recommends not more than 2 spacers. I've run 2 with 882 and had no problem. When I installed Tundra coils, truck was perfectly level. Are you sure that you put each coil to it's specific corner?
Old Dec 8, 2004 | 09:12 AM
BajaRunner's Avatar
I run a 2.5" cornfed, 881 and 5mm trim packer.
They sell 10mm trim packers, which would probably give you 1/4-1/2" of lift only.
Old May 7, 2005 | 03:58 PM
ROOFGOOF's Avatar
I know this thread is alittle old, but here is my scenerio... if I have a one inch cornfed spacer up front and one inch spacer in the rear....and I get a slight rear sag due to a safari rack/spare tire could I use a trim packer to add alittle height on the cornfed spacer in the rear to achieve a level stance or a slight rake ???
Thanks.
kawazx636
Oct 6, 2021 03:03 PM
matmattmatthew
10
Feb 9, 2021 04:15 PM
BimmerSage
Sep 17, 2015 11:48 PM
BimmerSage
New York
Sep 17, 2015 05:21 PM
