How long will that engine go?
Old Jan 21, 2004 | 11:06 AM
RigRunner's Avatar
I have a 91 Reg. Toyota and have almost 203K on the engine. How many miles have you guys put on your Yota that are really high? Will i be able to get it to 250K if it doesnt start burning oil by then?
Old Jan 21, 2004 | 12:40 PM
GoudyMan's Avatar
i would think so as long as the oil has been/ and will be changed regularly.
Old Jan 21, 2004 | 12:45 PM
KING's Avatar
6 cylinder or 4 cylinder?
You should be able to tell just how strong it is.
If you feel like the engine is getting kind of lousy, then more than likely it will not get to 250K.
If you feel that it still has that bit a power you need, then I would assume you have a great possibility to get there.
By no means, is this a professional answer.
Old Jan 21, 2004 | 01:53 PM
Mike Murrell's Avatar
'83 22R pick-up. Sold about a yr. ago. Had a hair over 300,000 miles on it. It's still running.
It's all about the 2 "F" words.
Fluids 'n Filters.
Old Jan 21, 2004 | 02:31 PM
RigRunner's Avatar
Fluids and Filters. (i.e. oil and oil filter right?). yea i change them regularly.
It runs just as strong as it did when i bought it.
Old Jan 21, 2004 | 02:37 PM
[QUOTE]Originally posted by RigRunner
[B]Fluids and Filters. (i.e. oil and oil filter right?).
Plus
Coolant - drain once a year. Radiator and block. Flush both ways. Use 50/50 coolant & distilled water. I replace t-stat when I do this. Cheap insurance.
Outer belts every 3 yrs. or so
Transmission fluid/oil + filter if you have one once a yr.
Differentail gear oil - change once a yr.
Brake fluid - flush/bleed every couple of yrs.
Adj. valves once a yr.
Spark plugs once a yr.
Rotate tires a couple of times a yr. or more if you like.
Power steering fluid - flush/refill if you have it - check grease in steering box a couple of times a yr.
Don't drive the thing like you race for a living.
Jun 1, 2021 01:51 PM
icentropy
Sep 16, 2020 02:47 PM
Colington
Mar 8, 2020 09:51 AM
razorman8669
Jul 12, 2015 12:13 PM
akaphilly
Jul 9, 2015 02:34 PM
