How do you remove panel covering seatbelt mech
Old Jan 12, 2003 | 01:13 PM
swerks's Avatar
I would actually like to know how all the interior panels come off. I know there are good writeups on the doors and dash but what about the rear panels the lift gate and seatbelt pillars??? I am speaking 3rd gen here. can any one help me out ??
Old Jan 12, 2003 | 11:35 PM
butnut's Avatar
The side pillar panels pop off. You have to remove the lower scuff panel first. All panels have clips that can break...they are plastic and will probably get more brittle with age. Use care and finesse, pry with a slot driver if you can see the clip to pop it. The rear cargo area is also all clips. Remove the scuff panel first and work your way up. I pulled the sides to install eye hooks for my cargo net, I did not completely remove it, but I assume it's all clips holding it in. Clip's are'nt designed to be removed a lot of times...be careful. It's luck too.
butnut
Old Jan 13, 2003 | 01:17 AM
swerks's Avatar
can these clips be replaced if broken??? thanks for the info!
Old Jan 13, 2003 | 07:37 AM
butnut's Avatar
Most likely a dealer item. Good luck.
Old Jan 13, 2003 | 07:47 AM
PhxTRDRunner's Avatar
They are a dealer item - but if they do not break completely, you can rebend them to make a nice tight fit again
westonian18
May 1, 2020 06:38 AM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
irritech
Jul 27, 2015 05:15 PM
rushw
Jul 18, 2015 01:46 PM
