How difficult is a 3.4L swap to my 1988 3.0L?
Old 12-05-2002, 09:32 AM
4RUNNER88's Avatar
My 1988 4Runner is all restored except for the engine.
I would like more HP and TQ but have not found much available for my 3.0
How difficult would it be to install a 3.4?
Old 12-05-2002, 10:01 AM
Toddski's Avatar
I dont know how hard it would be BUT!
I'm flying you down to do my 4runner if you do the swap
Old 12-05-2002, 11:28 AM
Churnd
Guest
Posts: n/a
not too hard at all. do some searching for a company that makes a wiring harness for the swap b/c i know there is one. the motor mounts are supposed to be the same. the only problems you should encounter are the exhaust, fuel lines, etc, are on the opposite sides. also you'll need a 2" body lift to clear the height of the motor. make sure whatever tranny you have (auto, manual) you get an engine that was mated up to the same type of tranny. those are the only problems i've heard of that i can remember off the top of my head. i'll post more if i think of them later.
Old 12-05-2002, 01:43 PM
4RUNNER88's Avatar
Churnd,
Thanks for the info. It sounds like it could happen!
Old 12-05-2002, 02:02 PM
Churnd
Guest
Posts: n/a
thought of one more thing. try to find a 3.4 out of a T100 so the sump on the oil pan will be on the same side to clear the front differential. if you don't, you'll have to use the oil pan off of your 3.0, and i'm not exactly sure how that's done but it can be done.
here's a link to that wiring harness i was telling you about. wiring harness . here's another article about a guy who did a similar swap: swap
Old 12-05-2002, 06:25 PM
4RUNNER88's Avatar
Churnd,
Thanks again. Some very good information.
Old 12-05-2002, 10:44 PM
mogwai snot's Avatar
I have an 88 4Runner, and I will be doing the swap probably next spring. Churnd mentioned basically all of the "trouble" areas that need to be worked out. I have a 3.4L engine that I am rebuilding right now, just have to find a tranny and marlin crawler T-case adapter so I can use my existing T-case from my runner. I will have to get custom fuel and power steering lines. As for the oil pan problem, I will be doing a SAS at the same time so no worries. Goodbye 22RE, hello 5VZFE balls.:tomcat:
mskalmus
05-28-2017 07:51 AM
_Nicco_
08-28-2015 07:26 PM
Backcountry411
07-24-2015 08:06 AM
1996Taco
07-20-2015 12:02 AM
Quick Reply: How difficult is a 3.4L swap to my 1988 3.0L?
