How can I tell which alternator I have?
Old Oct 13, 2006 | 09:28 AM
runnerSR5's Avatar
This could be a newbie question. I did search.
Saw a high output alternator for 4runners and tacomas that says it has 160 amp capability. How can I tell if I have a regular alt or a high output already installed? I don't have any guages that tell me how many amps or volts I'm using. Is there a certain part number I should be looking for without actually removing my alternator?
Old Oct 13, 2006 | 11:39 AM
pat161's Avatar
I was under the impression that 3rd gens had either a 70 or 80 amp alternator. Off topic but, did you swap the e-locker into your 01?
Old Oct 13, 2006 | 11:41 AM
DeathCougar's Avatar
Is it a factory alternator? IE does it have the factory part numbers on the casing??
Old Oct 13, 2006 | 12:06 PM
profuse007's Avatar
even if its a rebuilt alternator, you wont notice the physical differences. so, you wont know unless you track down the internals. btw, there are several components replaced to give a higher current output.
Old Oct 13, 2006 | 12:34 PM
runnerSR5's Avatar
E-locker was there when I bought it. Looks like a factory job, even though I read somewhere they stopped offering that as an option for '01 4runners.
It says toyota on it. The only numbers I can make out are ?????-62160. I wasn't sure if perhaps there was a factory option for a high output alt or something.
shooter86314
Jan 7, 2016 07:05 AM
Chicken12
Oct 14, 2015 03:54 PM
fountain
Sep 28, 2015 03:04 AM
SCZIG
Sep 20, 2015 09:00 AM
scheuvront1993
Sep 17, 2015 06:17 PM
