Horrible Gas Smell - New VC Gasket, PCV, Plugs, and Plug Wires
Old Oct 2, 2012 | 07:40 PM
thrice1825's Avatar
Here's my sad embarassing story:
I replaced my valve cover gasket (passenger side), replaced the spark plugs, plug wires and PCV. In doing so I also used new gaskets for the throttle body and air intake.
I went to start the car up and it will start but smells like gas...it's horrendously strong and shakes like it's misfiring.
Can anyone give me advice on where to even begin to look?
Old Oct 3, 2012 | 01:50 AM
vital22re's Avatar
totally a bro
did you plug in the coil packs? did you properly route the 3 spark plug wires? did you use the proper spark plugs? did you plug in the tps? Did you plug in the vacuum hose under the throttle body? etc... etc... etc...
Old Oct 3, 2012 | 05:15 AM
thrice1825's Avatar
I think you may have saved my bacon.
I routed from
cylinder 5 to 2
cylinder 3 to 4
cylinder 1 to 6
From the sounds of it, it should be routed from
cylinder 5 to 2
cylinder 3 to 6
cylinder 1 to 4
Does that sound correct? Would that cause the toxic gas smell?
Old Oct 3, 2012 | 08:18 AM
TheDurk's Avatar
I routed from
cylinder 5 to 2
cylinder 3 to 4
cylinder 1 to 6
cylinder 5 to 2
cylinder 3 to 6
cylinder 1 to 4
Oh yeah. And option #2 is correct. There is always a difference of three between opposite cylinders on this motor. That's how I remember it.
Old Oct 10, 2012 | 06:19 PM
thrice1825's Avatar
That's a good way to remember!
For anyone in the future who is having the same issue, the cause was the spark plug wires. After making the corrections listed above the smell disappeared and the car ran great. Thanks for all the help everyone.
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
steve miller
Oct 10, 2015 01:40 AM
smiley52
Jul 11, 2015 05:16 AM
bryan34w
Jul 6, 2015 05:53 PM
toyota32
Jul 6, 2015 05:42 PM
