High RPM Rattle
Old Apr 20, 2004 | 03:01 PM
yigo65's Avatar
High RPM Rattle
I just picked up an 86 4x4 for a steal. I replaced the clutch, did a tune up, changed belts etc. The truck runs well but I have noticed one thing. When going through the gears at a high rpm before shifting to the next there is a very noticeable rattle. I haven't noticed it in 4th or 5th as I haven't taken it above 65. Also when in third it usually starts doing it between 35 - 40mph, but when going up a decent hill at the same speed it doesn't. Last thing when in neutral and gassing it it will rattle to some extent, but its when I'm really rev'ing the motor. Any suggestions?
Old Apr 20, 2004 | 03:17 PM
rimpainter.com's Avatar
Does it rattle at start-up at all?
Worst case scenario is timing chain guides. Best case scenario is an exhaust heat shield(s). I would start cheap first. Get under the truck and bang around the exhaust with a rubber mallet. Look for loose fittings and listen for sounds.
That should be a good start.
Just so you know, the 22re has plastic timing chain guides that are prone to fail.
I am assuming that is what you have anyway.
There are other things...but let's start there.
Old Apr 20, 2004 | 04:13 PM
yigo65's Avatar
Nope it doesn't rattle at start up. I'l crawl up under there and see what happens.
Old Apr 20, 2004 | 04:51 PM
Brendan's Avatar
rattle as in the truck shaking or a rattling sound? rattling sound is quite likely the timing chain against the timing cover
Old Apr 20, 2004 | 05:00 PM
yigo65's Avatar
rattling as in a sound, kinda sounds like a diesel when its doing it.
Old Apr 20, 2004 | 05:28 PM
You mean detonation, like pinging?
Old Apr 20, 2004 | 05:49 PM
Brendan's Avatar
could be valves needing adjustment too
Old Apr 20, 2004 | 06:42 PM
yigo65's Avatar
No, it's a definite rattle noise, not a ping. To steal someone elses description I saw, like a ball bearing in a coke can.
Old Apr 21, 2004 | 03:36 AM
CTB's Avatar
CTB
Sounds like pinging to me....
JNapolitano
Nov 14, 2019 07:46 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
